Thread: Swapped engine, trans, and pcm now no start
Results 1 to 17 of 17
  1. #1 Swapped engine, trans, and pcm now no start
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    Hi recently we swapped the engine, trans and pcm from a 05 GTP to a 05 GT and we can't get it started. All the dash lights come on and we have power to the starter, but nothing happens when we turn the key. Any suggestions from the experts would be greatly appreciated.
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  2. #2 Re: Swapped engine, trans, and pcm now no start
    All grounds are hooked up and snug right?
    No blown fuses?
    Maybe swap the GT pcm in and see if it starts.
  3. #3 Re: Swapped engine, trans, and pcm now no start
    Dec 2012
    Where 4T65E's were born
    When you say power to the starter, you mean constant power at the big gauge wire, and also power at the solenoid wire when you turn the key? If you have both those, and the engine/trans ground hooked up, either the starter goes or it's bad.
    Sold.
  4. #4 Re: Swapped engine, trans, and pcm now no start
    Jul 2010
    Detroit
    No blown fuses?
    I was thinking about doing that but I was afraid of messing something up with the engine because one is made for a sc car and such. I'll double check the fuses. Do you think it could be pk3 related?
    Ryan
  5. #5 Re: Swapped engine, trans, and pcm now no start
    Jul 2010
    Detroit
    Yes we've check all the connections over a few times. I was curious if you think pass key 3 is locking us out? Considering the wiring harness, and pcm is from the donor GP with different keys and programming...
    Ryan
  6. #6 Re: Swapped engine, trans, and pcm now no start
    Dec 2012
    Well when I meant check it, I meant get under and check it right at the starter. You can see if you're getting power right to it (at the solenoid wire when the key is turned to crank) If not, then I'd check connections(you did) and lastly, things with security like passkey or something.
    Sold.
  7. #7 Re: Swapped engine, trans, and pcm now no start
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    dont the PCM and BCM need to have the same vin for everything to work? so if you swapped the PCM that came with the new engine, but not the BCM you would have mis'matched vins.
  8. #8 Re: Swapped engine, trans, and pcm now no start
    GTP Level Member tms8582's Avatar
    Washington Michigan
    I missed seeing one of the starter wires once after a motor install once. I believe there is three wires and one of them was hiding. There's also a ground or two on the trans. I missed seeing one of those once too. Lol
  9. #9 Re: Swapped engine, trans, and pcm now no start
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    I'm thinking what fivefinger and orange touched on... swap PCM and see if it starts. Car will run with the GT PCM, but not "great" But if it starts with your original GT PCM then you know there is miscommunication between your stock BCM and the GTP PCM out of the other car.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  10. #10 Re: Swapped engine, trans, and pcm now no start
    Jul 2010
    Detroit
    Ok here's where we are... we put the gt pcm in and it started. So after that we had it towed to a Chevy dealership and had them program the Gtp pcm to the vin. Now it runs, but like crap. Something regarding the map sensor we were told.
    Ryan
  11. #11 Re: Swapped engine, trans, and pcm now no start
    If they programmed the pcm to the vin, they put in the NA tune I'd bet. Because when they pull the most current tune for a vin..that's what they'll see.
  12. #12 Re: Swapped engine, trans, and pcm now no start
    Jul 2010
    Detroit
    Ok so we need them to program the bcm and the pcm to the gtp tune?
    Ryan
  13. #13 Re: Swapped engine, trans, and pcm now no start
    Feb 2009
    flintnasty MI
    You just need a GTP pcm... You had one but for some reason you had them flash it back to the same pcm you already have????
    You need to go and (buy) another PCM then sync it to the BCM. PCM relearn procedure
  14. #14 Re: Swapped engine, trans, and pcm now no start
    Jul 2010
    Detroit
    We only did that because it wouldn't start with the one from the GTP. The idea wasn't to get a GT tune flashed on the GTP pcm, and I'm not exactly sure if that's what the dealership did or not. I'm posting this for a member in my local car club because he's not on the forums. I must have did a terrible job of searching, I couldn't find the answer anywhere on here. That was the reason for this post. I appreciate your willingness to help.
    Ryan
  15. #15 Re: Swapped engine, trans, and pcm now no start
    Feb 2009
    flintnasty MI
    might be a good idea to share what map sensors you have on this, because you have to have a very specific combo for each PCM for things to work correctly.
  16. #16 Re: Swapped engine, trans, and pcm now no start
    Jul 2010
    Detroit
    The engine and trans including all sensors with the exception of the oxygen sensors were from the donor car. (GTP) Even the wiring harness is from the GTP.
    Ryan
  17. #17 Re: Swapped engine, trans, and pcm now no start
    Jul 2010
    Detroit
    Btw, that whole let me Google that for you thing was kinda funny... I'm not one to just post random questions without searching first. I didn't see any threads on GPF with my exact issue.
    Ryan
  1. Topped swapped 06 GP now wont start and scan tool wont comm with ECM
    By jbrltoliver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-31-2013, 08:36 AM
  2. Replies: 3
    Last Post: 05-27-2010, 12:31 PM
  3. Top Swapped 06- Wont start
    By Crispix396 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2010, 09:05 PM
  4. 2002 Regal GS motor/trans swapped into a 97 GTP??
    By toast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2009, 11:05 PM
