Thread: Driverside power door unlock issue
Results 1 to 2 of 2
  1. #1 Driverside power door unlock issue
    SE Level Member Reverant GTP's Avatar
    Iowa
    I have a 2004 Comp G with a non working driverside power lock not operating. I bought the car this way so i have no history. I have replaced the motor inside the door that operates this function, thinking it was that. However upon replacement it still does not work. Any ideas? All the other doors work just fine with the key fob or the button. Just the driverside i have to operate manually.
  2. #2 Re: Driverside power door unlock issue
    St. Louis
    Might be time to open the door panel up and check for power at the harness with a multimeter. May have a broken wire to it somewhere. I also wonder if the master switch is bad if it will prevent the keyfob from unlocking it as well. Never tried before. Just thinking outloud here.
  1. Door locked, can not unlock or open
    By Lowdown112 in forum General Grand Prix Discussion
    Last Post: 12-11-2012, 02:19 PM
  2. Driver's door power lock issue.. :(
    By daiadvisor2 in forum General Tech Discussion
    Last Post: 09-05-2010, 08:13 PM
  3. Key won't unlock door
    By dirtmaster88 in forum General Tech Discussion
    Last Post: 01-05-2010, 05:01 PM
  4. Driver door up, driver side unlock and power mirrors are out!!! Help
    By Dangerous313KidInAPrix in forum Audio, Security & Visual Electronics
    Last Post: 11-25-2009, 12:12 PM
  5. Tuner Changes for TCC Lock/Unlock Issue
    By Lawngoose in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2009, 10:42 AM
