Thread: Help it's going crazy!!!!
Results 1 to 19 of 19
  1. #1 Help it's going crazy!!!!
    Dec 2012
    wichita,ks
    Alright I just put a narrowband afr in my car and its going crazy heres a video please help yes I'm putting a wideband in when I get my tune done its temporary until then it was 15$
    It is just a FAMILY CAR
  2. #2 Re: Help it's going crazy!!!!
    The Boss Iceman6669's Avatar
    Jun 2011
    Yep.. Narrow Bands do that.....
    2011 F-150 Yote powered
  3. #3 Re: Help it's going crazy!!!!
    Narrow band gauge follows the actual o2 sensor readings, thats why its a crazy light show.
    Take it out because it does nothing.
  4. #4 Re: Help it's going crazy!!!!
    Dec 2012
    wichita,ks
  5. #5 Re: Help it's going crazy!!!!
    Dec 2012
    wichita,ks
    Lol I like the light show but I've had a wideband in my eclipse and the lean and rich freaks me out hahaha, I guess I'll let it be a light show for a little until I take it back lol, I put it in to fill in my pod lol.
  6. #6 Re: Help it's going crazy!!!!
    Let me put it this way.
    The car is always trying to reach stoich, so when it use's the o2 sensors that is what you are seeing. They go lean to rich and never stop doing that. So when you see it on a wideband the numbers bounce around from 14-15.3ish as stoich is 14.7. All of that is completely normal to see. Now if you were going WOT and you see the WB going from lean to rich and so on, then you have an issue.
  7. #7 Re: Help it's going crazy!!!!
    Dec 2012
    wichita,ks
    Ya I know on a wideband my eclipse stayed at about 14.9 on a Plx wideband I'm going to go with a aem I think when I get my wb I always liked the look of them! So ill have a light show for now I guess it'll look funny when someone sees it and says what is that haha
  8. #8 Re: Help it's going crazy!!!!
    Dec 2012
    wichita,ks
    I didn't think it would be that wild though so lesson learned.
  9. #9 Re: Help it's going crazy!!!!
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    I installed Universal 2" 52mm Air Fuel Ratio afr Volt Blue Digital LED Combo Gauge Smoke Len | eBay that to fill my hole its a digital volt and it is a nb afr gauge but gives u a digital afr read out seems to be around 14.6 to 15.4 crusing light throttle and lean rich at idle but at wot I am seeing 12.0 to 11.5 depending on fuel and air temp so seems to work ok doesn't flop as bad as that lol
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  10. #10 Re: Help it's going crazy!!!!
    Banned
    Jan 2013
    the bandwagon follower aka noobiee
    look good nice pull what have done to that =]
  11. #11 Re: Help it's going crazy!!!!
    I'm sitting here grinning a bit.
    You put in a gauge w/o reading up on what you were monitoring, then freaked out because it was working properly. Tha'ts pretty darn funny.
  12. #12 Re: Help it's going crazy!!!!
    Dec 2012
    wichita,ks
    Import it is all stock and bill it's a funny haha thread now but at first in the video I was like umm ya, but it's a narrow band that cost 15 bucks its worthless and just filling a pod I like the flashing lights but the bel air pd didn't like it lol, they thought I was acting like them with the red and blue lights haha. And I figured that it wouldn't bounce around that much but I was wrong, shame on me for thinking haha,
  13. #13 Re: Help it's going crazy!!!!
    Dec 2012
    wichita,ks
    Quote Originally Posted by 00grandprixgtp View Post
    i would be screwed with this guage!!! My car can't deside if it wants 14.3 or 15.8 volts haha so it goes back and forth!!
  14. #14 Re: Help it's going crazy!!!!
    Apr 2009
    Elkhart
    LOL ya if it changed in volts it lights the red led and the dig goes back to volts also goes to volt when starting fig for 20 buck its a nice gauge hole filler
  15. #15 Re: Help it's going crazy!!!!
    You do realize.. AFR isn't volts. 14.7 stoich is air to fuel ratio as in 14.7 parts to 1. The NB gauge is going to read likely 0-1000 mV
  16. #16 Re: Help it's going crazy!!!!
    Dec 2012
    wichita,ks
    Who is that to bill?
  17. #17 Re: Help it's going crazy!!!!
    You ..
  18. #18 Re: Help it's going crazy!!!!
    Feb 2009
    flintnasty MI
    I run one of these gauges on my racecar fiero.... it goes 10.0 and that gauge sits up on my dash haha.
  19. #19 Re: Help it's going crazy!!!!
    Dec 2012
    wichita,ks
    Yes I do realize this, I've had a 350hp eclipse on 10lbs of boost and 450 on 20lbs I do know what a wideband is and how they read, not being rude just saying.. Thanks though bill.
  1. Crazy KR
    By biggt in forum General Tech Discussion
    Last Post: 03-29-2012, 07:14 AM
  2. Help me my car is going crazy!!
    By csssaint12 in forum Audio, Security & Visual Electronics
    Last Post: 04-22-2011, 12:53 PM
  3. This is crazy
    By Ricky21 in forum Off Topic Discussion
    Last Post: 09-21-2010, 08:10 PM
  4. This is crazy
    By 40mphGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2010, 07:32 PM
  5. crazy car need some help
    By KingOfTheSouth in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2009, 12:29 AM
