Thread: How to remove a maxi fuse.
Results 1 to 10 of 10
  1. #1 How to remove a maxi fuse.
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Those gray relay looking things (I think they are called maxi fuses or something), I need to try to get my fog lights working again. I can't figure out how to remove them. I pull and pull and no bueno. Is there a special trick?
    2012 F150 STX
    - Gonna be a race truck
  2. #2 Re: How to remove a maxi fuse.
    Pull harder.
  3. #3 Re: How to remove a maxi fuse.
    Apr 2012
    Dayton, OH
    I am thoroughly retarded.....I need to hit the gym.....
    2012 F150 STX
  4. #4 Re: How to remove a maxi fuse.
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    I dont think they let retards workout at the gym... well at least not on the free weights lol
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
  5. #5 Re: How to remove a maxi fuse.
    SE Level Member blackgtp95's Avatar
    Jun 2011
    Toledo,OH
    Pliers maybe? They can be a little tight sometimes, I've had to rock them back and forth a couple times before they come out
  6. #6 Re: How to remove a maxi fuse.
    Apr 2012
    Dayton, OH
    Quote Originally Posted by Neil98gt View Post
    2012 F150 STX
  7. #7 Re: How to remove a maxi fuse.
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    when I removed a one I always just opened her legs and took it out....oh wait that's a maxi pad my bad always get those 2 mixed up
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  8. #8 Re: How to remove a maxi fuse.
    Apr 2012
    Dayton, OH
    Thanks guys I got it
    2012 F150 STX
  9. #9 Re: How to remove a maxi fuse.
    did you hit the gym? Cause...you seem to have needed it
  10. #10 Re: How to remove a maxi fuse.
    Apr 2012
    Dayton, OH
    Nah but a screw driver got the relay out for the fog lamps, switched with horn and still no fog lamps. Removed dash bezel to look at switch connection and it was fine Could that switch possibly have died when its on the amber light doesn't even light up. I still haven't checked the bulbs yet as I don't think its the problem but I will when its not 85 beating on me next to a black car. I have a feeling I'm de-railing the thread from what I originally started off asking...
    2012 F150 STX
  1. Which fuse?
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 08-28-2011, 08:33 PM
  2. Big 3 fuse
    By c32k05 in forum Audio, Security & Visual Electronics
    Last Post: 04-21-2009, 02:06 PM
  3. Fuse box
    By RPM_INC in forum General Tech Discussion
    Last Post: 07-12-2008, 03:43 PM
