Thread: Motor swapping an L67 into another car
Results 1 to 14 of 14
  1. #1 Motor swapping an L67 into another car
    Banned
    Jan 2013
    Colorado
    What is the ease of swapping a supercharged L67 motor into a Grand Am GT? Just curious cause I think they look a lot better than GP's.
  2. #2 Re: Motor swapping an L67 into another car
    GTFO.
  3. #3 Re: Motor swapping an L67 into another car
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    If you live around Denver, make a trip to aurora on a friday night to the Car show at Hampden and Tower. There's a kid there with a GAGT that swapped in a G6 GXP motor with a GEN 3 supercharger on it. It looks ugly as sin. But it's kinda quick...
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  4. #4 Re: Motor swapping an L67 into another car
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    damn rocked a 3.6 ohc supercharged u gotta get some pics that's gotta be a hell of a intake
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  5. #5 Re: Motor swapping an L67 into another car
    You think ga's look better than gp's? Wow first time I've ever heard that.
  6. #6 Re: Motor swapping an L67 into another car
    Banned
    Jan 2013
    Colorado
    Yeah so is it possible or too much work?
  7. #7 Re: Motor swapping an L67 into another car
    I'm sure it's possible. You'd probably have to fab motor and trans mounts and figure out the wiring.
  8. #8 Re: Motor swapping an L67 into another car
    new britain, ct
    its possible, some guy on here had one.
    go to youtube and look it up.
    07 Black GXP.
  9. #9 Re: Motor swapping an L67 into another car
    I'd google search it.. I know it's been done a few times. See what info you can dig up.
    Agreeing with you. Nearly anything is better looking and more comfy than a GP.
  10. #10 Re: Motor swapping an L67 into another car
    Banned
    Jan 2013
    Colorado
    seems like the wiring would be the hardest part.
  11. #11 Re: Motor swapping an L67 into another car
    For that, I'd grab pieces at a JY and make an adapter from the wiring harness for the engine to the car.
  12. #12 Re: Motor swapping an L67 into another car
    Feb 2009
    flintnasty MI
    wiring is easy, gauges are not that easy to hook up, if you can even do it. The GA dash runs on the pcm.
  13. #13 Re: Motor swapping an L67 into another car
    Hmmm I'd look at some of the various years/models, bet you can get it. I remember the intrigue runs a lot of the cluster off the pcm. I think the Bonnevilles (00+) did the same, I'd bet the 04+ gp's do as well.
  14. #14 Re: Motor swapping an L67 into another car
    Feb 2009
    flintnasty MI
    Then you still need to sync the BCM.. Im sure you could find a magical combination, but good luck.
  1. Motor and trans mount swapping
    By BillBoost37 in forum General Tech Discussion
    Last Post: 04-18-2013, 12:00 PM
  2. 98 GTP swapping non S/C 3.8
    By brktracer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2013, 09:07 AM
  3. swapping
    By coreysGTP in forum Introductions/Noob Questions
    Last Post: 12-28-2012, 10:35 PM
  4. swapping an ls4 into a 97-03 gp
    By NineD9GT in forum General Tech Discussion
    Last Post: 06-29-2010, 08:26 PM
  5. Swapping PCM's
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2009, 09:34 PM
