Thread: gtp running rough tried plugs, wires, new mas air, vac. lines, just no luck
Results 1 to 3 of 3
  1. #1 gtp running rough tried plugs, wires, new mas air, vac. lines, just no luck
    Apr 2013
    United States
    I cant figure out my rough running gtp. I have a lean in bank 1 code 0171 i believe, i put new plugs and wires on, new mas air. , checked for vac leaks and im having no luck, I have 2.5 headers, with 3" all the way back running 3.25"pulley anyways im stuck on this Any ideas for me that be great. thanks
  2. #2 Re: gtp running rough tried plugs, wires, new mas air, vac. lines, just no luck
    antioch ill
    so you just have headers and dropped to a 3.25?
  3. #3 Re: gtp running rough tried plugs, wires, new mas air, vac. lines, just no luck
    Do you have a code reader than can do live data or a scangauge that can?
    Check to see what your long term fuel trims and MAP in vacuum is reading.
    Sounds like it still has a huge exhaust leak or somthing internal is wrong.
  1. Maintenance gone wrong - wires/plugs - NOT RUNNING
    By HEVEYMETIL in forum General Tech Discussion
    Last Post: 04-10-2013, 02:00 PM
  2. 2006 GP idling rough, already replaced plugs and wires.
    By Cliffey Wan Kenobi in forum General Tech Discussion
    Last Post: 03-02-2013, 08:06 PM
  3. rough idle after new plugs and wires
    By carr08 in forum Introductions/Noob Questions
    Last Post: 09-14-2012, 01:34 PM
  4. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  5. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
