Thread: Rubber Windshield Molding
Results 1 to 2 of 2
  1. #1 Rubber Windshield Molding
    SE Level Member Pairsnpaint's Avatar
    Ocala, FL
    About a year ago I had my windshield replaced, and afterwards would get the dreaded water in the passenger footwell when it rained. (The shop that did the replacement has since gone out of business, so going back to them is not an option). I went through all the normal fixes (cowl deflector, drain ports, etc.) to no avail. Today I replaced the blower motor as the old one rusted out due to the leak. Now I notice that the rubber molding at the top corner of the windshield is pulling away. I was unable to just push it back into place. Is there a special tool or procedure for reinstalling the rubber molding? I'm tempted to pull it all out and force some silicon into the channel to stop the leak, but not sure if I would be able to replace the molding after doing that. Any suggestions? Thanks.
    Hal
    Ocala, FL
    2002 GTP Coupe - 2016 Chevy Equinox
  2. #2 Re: Rubber Windshield Molding
    St. Louis
    Did they reuse the factory reveal moulding on the new windsheild, or just install that cheap one-size-fits-all crap out of a box?
    Reason I ask is that the factory stuff has a channel built into it that actually holds on the glass. The cheap stuff they carry seems to just sit on the edge and can be pulled up/pushed back down.
    I'd get a tube of black winsheild urethane and run a bead in the channel and see if you stop the leak. I doubt regular silicone would hold up as long. Then while the urethane sets you can push the molding back down and use some tape to keep in place until it sets.
  1. Rubber key protector missing!!!
    By Grandprix202 in forum Visual/Body Modifications
    Last Post: 08-12-2013, 09:17 PM
  2. New gxp rubber? look bio!
    By jteske88 in forum Tires & Wheels
    Last Post: 05-31-2012, 01:06 PM
  3. where to get rubber t's for vac lines
    By e6600 in forum General Tech Discussion
    Last Post: 05-01-2010, 10:09 PM
  4. The rubber thing below the ignition on an '05...
    By SyriusX in forum General Tech Discussion
    Last Post: 05-26-2009, 01:19 PM
  5. new rubber on
    By QwikGT in forum Visual/Body Modifications
    Last Post: 08-02-2008, 06:25 PM
