Thread: 97 GRand PRIX GTP locks works but not on remote and bcm wont program
Results 1 to 8 of 8
  1. #1 97 GRand PRIX GTP locks works but not on remote and bcm wont program
    Apr 2013
    canada
    have a 97 GTP now the locks works if you use them in the car but the remote wont work so tried reprogramming the remote by populling the mall pgm fuse and turning the key to acc then to off and bacjk to acc then opening andd closin the drivers door, its now that im suppose to get a chime but i dont and cant continue with the programming,, so im stumped as to why the horn and trunk buttons work on remote but not the unlock and lock and i cant reprogramm the remote, anyone got any ideas pleas Thank you ASH
  2. #2 Re: 97 GRand PRIX GTP locks works but not on remote and bcm wont program
    Sep 2011
    Copperas Cove, TEXAS
    I had this problem also, so I ditched the factory crap and installed a remote start system that included Lock/unlock and trunk. Got it from autozone for $99.
    Welcome to GPF.
  3. #3 Re: 97 GRand PRIX GTP locks works but not on remote and bcm wont program
    Apr 2013
    canada
    thanks ya i might have to go that way cant track the problem down i think it might be the bcm itself
  4. #4 Re: 97 GRand PRIX GTP locks works but not on remote and bcm wont program
    Aug 2012
    Tukwila, Washington, United States
    Quote Originally Posted by ASHGTP View Post
    Ok here's a solution for you.
    I had same problem.
    There's a receiver under the dash behind the dic.
    Pull it out replace it with a different one (junk yard pick n pull cost 7$)
    Or buy from someone here for 30 with key.
    And it's gonna work perfectly.
    After that there's a thread I made about how to get a really good range.
    Look at my post you will find it.
    It's easier than you think. Good luck.
    Grand Prix gt 1999 v6 3.8L coupe.
  5. #5 Re: 97 GRand PRIX GTP locks works but not on remote and bcm wont program
    Apr 2013
    canada
    ok so under the dash behind the dic drivers instrument cluster? is that what your refering to raver...thanks for the info
  6. #6 Re: 97 GRand PRIX GTP locks works but not on remote and bcm wont program
    Aug 2012
    No. It's behind the display center (the thing that shows if ur door open,trac off etc.
    No screws needed. Just pull it. Find my post" how to get 200ft range"
  7. #7 Re: 97 GRand PRIX GTP locks works but not on remote and bcm wont program
    Apr 2013
    canada
    thanks im going to look for a replacement this weekend thanks again for the info and ill definately check your post
  8. #8 Re: 97 GRand PRIX GTP locks works but not on remote and bcm wont program
    Florida
    On a side note, you are turning the key backwards towards yourself correct?
    I just programmed 2 new key fobs yesterday, and felt like an idiot because I turned the key forward the first two times.
  1. Dealership can't program new keyless remote
    By Matticus in forum Audio, Security & Visual Electronics
    Last Post: 12-14-2012, 10:38 AM
  2. how to program 2008 grand prix gxp key fob
    By automech01 in forum Audio, Security & Visual Electronics
    Last Post: 07-26-2012, 02:23 AM
  3. Remote Program
    By grandamle91 in forum General Tech Discussion
    Last Post: 08-05-2011, 09:31 AM
  4. Remote Won't Program!
    By ljmonnin12 in forum Audio, Security & Visual Electronics
    Last Post: 03-16-2011, 09:03 PM
  5. How do you program a Viper 479V remote?
    By 007 in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2010, 12:53 PM
