Thread: Fuel line nut help..
Results 1 to 8 of 8
  1. #1 Fuel line nut help..
    Feb 2013
    Ohio
    Soaked fuel line nut with PB 3 days
    , used wrenches then two large vise grips left foot on one two arms on the other cant budge it. If I take plastic fuel line off will fuel stop draining ? So I can try to turn filter. Any other suggestions ? Might just cut with tubing cutter and use rubber fuel line to a connector that fits fuel filter. Thanks.
  2. #2 Re: Fuel line nut help..
    Hold the nut with a wrench and spin the filter off with a big pair of pliers.
  3. #3 Re: Fuel line nut help..
    Feb 2013
    Ohio
    Ok,thanks. So gas won't drain from plastic line while doing that ?
  4. #4 Re: Fuel line nut help..
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    I do not think the fuel line nut is a swivel. Be sure to use a flare nut wrench. Only turn the filter!!
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  5. #5 Re: Fuel line nut help..
    Feb 2013
    Ohio
    Thanks guys, no wonder I rounded that nut, didn't know it didn't turn.
  6. #6 Re: Fuel line nut help..
    Some will just throw a catch can under there
  7. #7 Re: Fuel line nut help..
    GT Level Member glendayle's Avatar
    Salt Lake City
    Mine was seized on. I unclipped the plastic side and cut it off the other side with a tube cutter. There are replacement sections you can get at almost all parts stores. I picked one up from Napa for $10. I also bought a tube bender from harbor freight for cheap. This kit comes with a compression fitting as well, but I was converting to SS lines so I did not use it. I had a swagelok to AN fitting I used.
    You can see I screwed up the 1st one here. The tube bender I had sucked, so I bought the one pictured for about $8. I then made a couple of test bends on the ruined piece before attempting to make my piece.
    1999 Regal GS Mods-180 tstat; CAI FWI; ubend delete/3"DPCB PLOG; HID fog conversion, 3.5, tint(42%/20%), TK Trans 3.29 gears
  8. #8 Re: Fuel line nut help..
    I'm pretty sure it's supposed to turn but most of the time gets rusted fast
  1. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  2. will a 97-03 L67 SC fuel line fit on my 97 GT L36?
    By mandingo in forum General Tech Discussion
    Last Post: 08-07-2010, 02:53 AM
  3. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  4. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  5. AN Fuel Line Setup
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2008, 06:26 AM
