Thread: Seat belt light on AFTER car is off
Results 1 to 17 of 17
  1. #1 Seat belt light on AFTER car is off
    SE Level Member gtpterp's Avatar
    Jul 2011
    MD
    Hey guys I am on the forum daily and have tried to do the search to fix the problem but cant find anything. I have a 00 gtp and just this morning the seat belt light came on. Searched around to find a thread saying to disconnect the sensor in the belt buckle to turn off the light. I found the one that connects to the buckle and disconnected it, but the light is still on...even when the car is completely off and I am outside of the car. This worries me because even though it is a small light, it can ultimately drain my battery. Is there any other way of disconnecting the light prior to going into the dash? (Trust me i tried disconnecting everything down there and the light is still on...).Thanks for the help
    -GTPTerp
  2. #2 Re: Seat belt light on AFTER car is off
    Hmmm interesting one that isn't common. Let's keep this up top until someone has the schematic/answer for you.
  3. #3 Re: Seat belt light on AFTER car is off
    Jul 2011
    MD
    Thanks bill!
  4. #4 Re: Seat belt light on AFTER car is off
    GTP Level Member
    springfield IL
    I had this happening when I first got my 00 Grand Prix back in 04... I bought the car from a bank because it was repossessed they had it rewired with the factory alarm shut off and that little seatbelt light has something to do with it being rewired. It never drained my battery but after a couple months of having it I took to Pontiac to a buddy of mine that worked there and they fixed it and I cannot remember what they did!!!! Sry!!! Lol
  5. #5 Re: Seat belt light on AFTER car is off
    Jul 2011
    MD
    bump any ideas?
    '00 GTP: TOG headers with high-flow Cat, Borla exhaust, 3.4 Pulley drop, 180* Tstat, NGK TR55
  6. #6 Re: Seat belt light on AFTER car is off
    SE Level Member USFrozen's Avatar
    Apr 2013
    Iowa
    Did you get it code scanned? p0650, the same code im getting, can set off any number of lights for no reason. (or so my research tells me... it may also keep lights from coming on in the first place.)
    The fastest things i own~
    Car: 2000 Pontiac Grand Prix GT
    Computer: Toshiba Qosmio x305, upgraded: Intel Core 2 Quad Q9000 @2.0ghz, GeForce 9800m OC'd, 8gb ram
  7. #7 Re: Seat belt light on AFTER car is off
    Jul 2011
    MD
    I don't have a CEL so no codes for me.... This is one of the weirdest problems I have come across...
  8. #8 Re: Seat belt light on AFTER car is off
    try un hooking the seat belt wire from the pass side? if it has one? not sure if the car cares if the passenger wears a belt or not.
  9. #9 Re: Seat belt light on AFTER car is off
    Apr 2013
    Iowa
    A lot of auto parts stores will do a free code scan. Kragen (aka O'Reilly) and Advanced Auto are two that i can verify by personally using their services.
  10. #10 Re: Seat belt light on AFTER car is off
    Jul 2011
    MD
    No passenger seat belt wire and not throwing any codes...Any other ideas lol
  11. #11 Re: Seat belt light on AFTER car is off
    SE Level Member bobeebob's Avatar
    chicago
    Are you having any problems with the lock cylinder?
    Silver Turd - 1998 ssei XP cam, Gen V, 3.8 pulley, 3.29 gears, intense mail order tune
  12. #12 Re: Seat belt light on AFTER car is off
    Jun 2012
    St. Paul, Minnesota
    My car started doing this shortly after I got it. It went away after I replaced the ignition switch.
  13. #13 Re: Seat belt light on AFTER car is off
    Jul 2011
    MD
    What problems would I encounter with the lock cylinder. I did however recently get two fobs synced to the car. I guess I should have mentioned that earlier. I synced them but everything was fine. then a day or two later the seat belt light came on...
  14. #14 Re: Seat belt light on AFTER car is off
    chicago
    For me i just had trouble turning the key out of the lock position, felt like I was using a worn out key.
    And are you able to use the accessories with the key out? (windows,radio,etc)
  15. #15 Re: Seat belt light on AFTER car is off
    Jul 2011
    MD
    No probs with turning the car on in any position (no sexual innuendos lol). damn light just wont turn off lol
  16. #16 Re: Seat belt light on AFTER car is off
    Jun 2012
    St. Paul, Minnesota
    Quote Originally Posted by gtpterp View Post
    After reading this I thought back and I had synced a fob right before mine came on as well.
    Keep an eye on your fan controls. Mine started working on and off shortly after.
  17. #17 Re: Seat belt light on AFTER car is off
    Jul 2011
    MD
    FIXED! disconnected the battery connected the sensor back and no light! thanks for all the help guys
  1. Seat belt warning Light stays on..all day.
    By brenglen in forum General Grand Prix Discussion
    Last Post: 06-26-2012, 05:51 AM
  2. Now what? Seat belt light and chime...
    By stealthee in forum 04+ Specifics
    Last Post: 11-27-2011, 12:18 AM
  3. Seat belt rewind and performance mode light
    By That Guy in forum General Tech Discussion
    Last Post: 08-01-2009, 04:39 AM
  4. seat belt ?
    By crewsn in forum General Tech Discussion
    Last Post: 04-17-2009, 10:19 PM
