Thread: hey guys, question about boost gauge
Results 1 to 20 of 25
  1. #1 hey guys, question about boost gauge
    Dec 2010
    DMV
    hey i just bought a gtp a few days ago and the boost gauge only shows one or two bars when i drive in performance mode. Any ideas? kinda new to this so im up to learning anything.
  2. #2 Re: hey guys, question about boost gauge
  3. #3 Re: hey guys, question about boost gauge
    Dec 2010
    DMV
    do i have to driving a certain speed for it to show? im really new to this whole thing lol and want to know as much info as possible. thanks
  4. #4 Re: hey guys, question about boost gauge
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Car wont show boost till 30 percent throttle or above, more throttle more boost, so if your seeing 1-2 bars @ 30percent id think thats normal. If your seeing 1-2 bars 100 percent throttle at 5K rpms then you have a issue. Id suspect the BBV,Map would be the issue. It would take a Huge vacuum leak to bleed boost. If you start your car and it sounds like a Huge cam Ls1 then maybe its a vac leak issue lol
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: hey guys, question about boost gauge
    Dec 2010
    DMV
    Ok lol I will try to decipher that. So if I'm going 30 or 40 mph it should show? Lol I'm such a noob
  6. #6 Re: hey guys, question about boost gauge
    Hagerstown,Md
    LOL..Ill put it in easier terms No Boost will show untill you push the gas peddel atleast 30 percent of the way down. The more you push the peddal down the more the boost will read.
  7. #7 Re: hey guys, question about boost gauge
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    ok here is how to check it for sure. take your car out driving and floor it and see how many bars you get at WOT. if u dont have all bars open your hood and locate your boost bypass valve on the supercharger. Here is a pic
    there will be two vacuum lines goin to it. one goes to from the bbv to the cap on top of the s/c like u see in the pic and the other is facing towards the front of your car. Unhook the rubber vacuum line that is facing towards the front of your car from the boost bypass valve. And then drive your car and go WOT and see if you have all your boost bars than. if you have all of them than you need a new bbv. Good Luck
    Bryant
  8. #8 Re: hey guys, question about boost gauge
    Dec 2010
    DMV
    Oh! Ok lol thanks! If I have any of the issues that you guys stated how much would it run me? I just got it and I like it
  9. #9 Re: hey guys, question about boost gauge
    Waterloo, Iowa
    hopefully its jsut the bbv cuz that is only 40 from zzp lol or possibly cheaper on rockauto
  10. #10 Re: hey guys, question about boost gauge
    Dec 2010
    DMV
    ??????! What does WOT mean? Lol
  11. #11 Re: hey guys, question about boost gauge
    Waterloo, Iowa
    i had the exhaust problem u r having bcuz my boost gauge was reading that im only puttin out about 4 psi from the s/c when im suppose to be puttin out about 10 psi. and i unhooked that vacuum line from the bbv and at WOT i got what i was suppose to be gettin and a new bbv fixed it
  12. #12 Re: hey guys, question about boost gauge
    Waterloo, Iowa
    wide open throttle. FLOOR IT lol
  13. #13 Re: hey guys, question about boost gauge
    Dec 2010
    DMV
    Thanks boost.
  14. #14 Re: hey guys, question about boost gauge
    Dec 2010
    DMV
    Great you guys. You guys are awesome!
  15. #15 Re: hey guys, question about boost gauge
    Waterloo, Iowa
    no problem sir hopefully its just the bbv... keep us informed
  16. #16 Re: hey guys, question about boost gauge
    Dec 2010
    DMV
    Will do
  17. #17 Re: hey guys, question about boost gauge
    Dec 2010
    DMV
    I have BOOST! I guess I wasnt flooring it enough! Thanks guys. But now I have another problem . The guy before me didn't tell me (maybe he didn't know?) but he has hid lights installed and whenever I turn them on my interior lights flicker and I felt the car lose power any help? It only happens when the hid lights are on.
  18. #18 Re: hey guys, question about boost gauge
    Waterloo, Iowa
    does it happen when u first turn them on? or does it consistantly happenw hen they r on?
    and what fixed your boost problem?
  19. #19 Re: hey guys, question about boost gauge
    West Side Michigan
    He probably does not have a relay harness for the HIDs. That would help big time with your problem. Relay harness is only about $10-$15..
    Not too hard to hook up, we can explain.
  20. #20 Re: hey guys, question about boost gauge
    Dec 2010
    DMV
    It happens consistently when they are on boost, and my foot fixed the boost problem lol. Now I know I need to hit it at WOT lol. And your guys have been extremly helpful. Where can I get a harness? And yes I would need instructions
  1. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  2. boost gauge question
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2010, 12:32 PM
  3. Factory boost gauge question (98GTP)
    By JoelW98GTP in forum General Tech Discussion
    Last Post: 11-08-2009, 08:06 PM
  4. question about boost gauge on a 98 gtp
    By millfire517 in forum General Tech Discussion
    Last Post: 02-09-2009, 08:31 PM
