Thread: Steering issue?
Results 1 to 5 of 5
  1. #1 Steering issue?
    Apr 2013
    Michigan
    I noticed this morning that when turning the wheel I get a whining noise and I have no idea why. My abs and trac off light are also on but I know that's a separate issue. Could it be a failing power steering pump? Any idea? Thanks lol
  2. #2 Re: Steering issue?
    GT Level Member Dakoda's Avatar
    Feb 2013
    Illinois
    whining noise is most likely your power steering pump... and your abs/trac light is probably a wiring/wheel hub issue
  3. #3 Re: Steering issue?
    Apr 2013
    Michigan
    It isn't making the noise when I turn now..?
  4. #4 Re: Steering issue?
    St. Louis
    Likely the pump is low on fluid, and when it's cold it makes it whine. After the fluid warms up and expands a bit the pump quiets down some. Time to fill 'er up.
  5. #5 Re: Steering issue?
    Setting it on fire can cure the issue.
  1. GXP steering rack issue
    By NorCalGXP in forum Brakes/Suspension/Chassis
    Last Post: 03-25-2013, 12:58 PM
  2. Steering/Voltage Issue?
    By mlasnoski in forum General Tech Discussion
    Last Post: 12-03-2011, 10:34 PM
  3. steering issue
    By macjns25 in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2011, 01:17 PM
  4. Power steering issue
    By izup69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2011, 10:57 AM
  5. power steering issue
    By tstaller2005 in forum General Tech Discussion
    Last Post: 04-27-2011, 10:05 PM
