Thread: HVAC Blower intermittent
Results 1 to 2 of 2
  1. #1 HVAC Blower intermittent
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Working on a 2004 Comp G. Fan works sometimes. It either will work flawlessly or not at all.
    I disconnected the blower motor and found a strong ground, but no power. Disconnected the wire harness from the resistor. Found a weak ground in the middle, but nothing on the rest.
    Should I be suspecting the HVAC control unit next?
    Sent from my SM-G920P using Tapatalk
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  2. #2 Re: HVAC Blower intermittent
    hangover park IL
    GM decided to make it so that 15 amps of current has to flow through a tiny f****** electrical terminal in a multi wire connector located behind the radio and HVAC consoles. This large red wire will typically have a burned terminal and the connector mean not unplug anymore you will have to cut it and directly spliced them. oftentimes just wiggling the connector will restore power for a short time.
    ~James~ Psychotic Gearhead
  1. blower motor intermittent
    By RedneckGTP in forum General Grand Prix Discussion
    Last Post: 12-01-2014, 03:12 PM
  2. intermittent blower on heater
    By vandezand in forum General Tech Discussion
    Last Post: 12-15-2012, 07:35 PM
  3. Blower motor intermittent help!! its cold in ak
    By ttjj1410 in forum General Tech Discussion
    Last Post: 12-10-2011, 03:12 AM
  4. Intermittent HVAC blower
    By Doc Banger in forum General Tech Discussion
    Last Post: 01-26-2011, 11:37 AM
  5. Intermittent Blower Motor
    By Securu99 in forum General Tech Discussion
    Last Post: 06-20-2010, 12:21 PM
