Thread: pinging only under load WHY ???
Results 1 to 5 of 5
  1. #1 pinging only under load WHY ???
    SE Level Member GAGT+GP-OWNER's Avatar
    May 2008
    DARTMOUTH, NOVA-SCOTIA,CANADA
    ...please read in it's detail >> i know i as talking about my 2007 grand prix 3.8L n/a. but your info should still help. notice begiining of oct COOL day when i loaded 4 winter tires 215/60/16 with 4 steel rims and aired up . 1 on each side of rear seat and 1 each bascially side by side in the trunk.
    i had to drive around a bit that day before and after load , so car was warmed up alot . everytime i stepped on the gas from a stand still or MANY times when i drove slow but had to step on the gas to pass etc. i would hear very load but breif pinging. i never paid any attention to rpms ( sorry )as to when it happened. after this i added a measured amount of fuel injectors cleaner to gas tank hoping that would fix .
    now at end of month bit cooler some frosty nights , this trip was at night and car was cold ,i had me and on passenger front seat and 5 in back seat plastic storage tubs , each filled with clothes . i would GUESS maybe 25 to 35 pounds each ??? and in trunk this time again guessing 50 to 70 pounds ?? i could hear on hard excellaration at various times and volumes the pinging still. not has often or as load as before with the rim/tire load.
    i use regular gas most often ESSO , car has 46,500 klms bought this may with 31,500 .
    these 2 loads times fresh ( less then 3000 klms on it ) regular oil ,not cheapy but not most expensive either , this time quaker state this time i believe ?? all other fluids are good.
    now this has a load carry rate ( occupants and load of of 917 pounds / 416kg ). ..i was way under that with the tub load + just me + trunk load Total 475 lbs ???
    and i am sure i was not even close to that with the tire/rim total guessing 635 lbs ?? . basically load no load no ping .
    with me + wife + 2 kids and normal trunk load 50 to 85 lbs, about 570 pounds , day old oil , long hwy trip etc ,again no ping
  2. #2 Re: pinging only under load WHY ???
    Feb 2008
    Do you have a sound clip?
  3. #3 Re: pinging only under load WHY ???
    May 2008
    i tried to make one with my digital as i drove but the wind made it un-noticeable.
  4. #4 Re: pinging only under load WHY ???
    Banned
    Wichita Falls, Texas
    Check the plugs, wires, coils, then the ignition module. Probably the ignition module, but thats also the most expensive part. So you should check the cheap junk first just in case.
  5. #5 Re: pinging only under load WHY ???
    May 2008
    well only one day 1/4 down from full tank of the higher octane 91 and the winter gasline antifreeze. i notice that i do still have a ping AT TIMES and RATHER lower in volume with none LOADS in the car. and only occurs with tramping on gas for a second. i know it maybe too early yet to see what effect on this pinging ( if any ) the higher octane 91 gas + gasline antifreeze + plus added today stp 2 in 1 octane boost that cleans also.
  1. Replies: 0
    Last Post: 08-24-2008, 12:43 PM
  2. Pinging???
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-06-2008, 11:41 AM
