Thread: replaced new blower resistor and still no heat
Results 1 to 5 of 5
  1. #1 replaced new blower resistor and still no heat
    chicago
    i just replace new blower resistor that i first thought was the problem why the heater won't come on. it's doing the same thing like before. when turning on to different selector i can hear little click like it want to turn on, but no heat coming out what so ever. i check fuses and they seem fine. what could this be? new blower wheel?
  2. #2 Re: replaced new blower resistor and still no heat
    Barksdale AFB, LA
    You could always jumper the blower to see if it comes on.
    Also, you may want to post up this problem on a Chevy board. More people know our HVACs over there, and it's pretty different from a GP HVAC as far as how it's wired.
    2009 Subaru Impreza WRX STI
  3. #3 Re: replaced new blower resistor and still no heat
    chicago
    this is on a 2002 gtp. what you do mean "jump the blower"
  4. #4 Re: replaced new blower resistor and still no heat
    Barksdale AFB, LA
    Quote Originally Posted by silverbullet View Post
    Then that's better.
    You can take a power wire and a ground wire to the blower's pins and manually try to get the blower to come on. This bypasses all of the car's controls and wiring and just tells you if the blower works. Then you can rule it out. I'd also take out the HVAC controls and multimeter them with a wiring diagram.
  5. #5 Re: replaced new blower resistor and still no heat
    chicago
    is that the only way to test it? i might take it to the shop and have them test it for. once i know what's wrong whether it's the blower or hvac control then i'll replace the part myself cause i can imagine how much the shop going to charged
  1. Blower Motor Resistor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 09-29-2017, 04:39 PM
  2. Blower Motor Resistor
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 02-28-2014, 05:34 PM
  3. Fuel Pump Resistor By Pass Mod
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2012, 05:49 AM
  4. Replaced pass. halfshaft - what did I screw up in the trans???
    By GTPrix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-25-2008, 12:00 AM
  5. The Old and The New, Blower Motor Resistor
    Last Post: 01-29-2008, 12:31 PM
