Thread: Turn signals turning on hazards?
Results 1 to 3 of 3
  1. #1 Turn signals turning on hazards?
    SE Level Member Jbruce308's Avatar
    Mar 2012
    Grand Rapids
    Okay so about 5 months ago i put my black spyder headlights in along with a pair xenon driving lights where the fogs go. Ive always kind of ignored it but for some reason my turn signals don't work.
    What happens:
    1. I turn on my headlights and on my dash i see both hazard lights turn on even though no lights arent blinking outside the car.
    2. When my headlights are off and i try to use my turn signals they do tick but instead of just 1 light blinking on my car, each light will blink as if i had my hazards on.
    3. Conclusion, i can not use my turn signals although they use to work way back like 8 months ago.
    I have checked the fuse and its good. So could it be the switch? A ground? and if so where? Or maybe spyder lights are causing some sort of short.
    What do you guys think? Leave replys on things i can do to trouble shoot this please. I hate driving without turn signals lol and manually using my arm out the window is no fun.
  2. #2 Re: Turn signals turning on hazards?
    Willoughby, Ohio
    there is a ground wire on the frame peice where the drivers side headlight mounts to, verify that has a good connection, also check any fuses involving the headlights/ high beams/ foglights
  3. #3 Re: Turn signals turning on hazards?
    Mar 2012
    Grand Rapids
    Quote Originally Posted by CTKGP09 View Post
    Alright will do. Giving it a look today.
    Thanks
  1. Replies: 1
    Last Post: 02-25-2012, 10:34 AM
  2. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
  3. turn signals.
    By Koniig in forum Visual/Body Modifications
    Last Post: 11-17-2010, 08:41 AM
  4. turn signals
    By echarleswhyte in forum The Rant Forum
    Last Post: 12-07-2009, 09:49 PM
  5. Turn Signals
    By brett88 in forum General Tech Discussion
    Last Post: 10-03-2009, 07:21 PM
