Thread: 00 grand Prix stutters when accelerator is pressed and depressed quickly...
Results 1 to 5 of 5
  1. #1 00 grand Prix stutters when accelerator is pressed and depressed quickly...
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    I have a 00 gp non supercharged 3800. I never noticed this when driving the car. 125,000 No check engine lights
    I sometimes rev the car up from the throttle from under hood to check for noises etc.
    If I push the throttle and release it very quickly the engine will make a noise and stumble. It has never cut off completely though.
    I was thinking maybe tps sensor...
  2. #2 Re: 00 grand Prix stutters when accelerator is pressed and depressed quickly...
    Clean the maf and check for vacuum leaks.
  3. #3 Re: 00 grand Prix stutters when accelerator is pressed and depressed quickly...
    Aug 2012
    Chicago
    That's the first thing I did... I will try and get a video of it though
  4. #4 Re: 00 grand Prix stutters when accelerator is pressed and depressed quickly...
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    if you can, post a vid. of it...
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  5. #5 Re: 00 grand Prix stutters when accelerator is pressed and depressed quickly...
    Aug 2012
    Chicago
    Here's a video also, it only does it when I let it idle all the way down then hit the accelerator very fast.
    https://plus.google.com/u/0/110585175429504708006/posts
  1. engine stutters
    By alivepills in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2010, 01:54 AM
  2. Stutters when floored
    By 1000PRIX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2010, 08:17 PM
  3. O2 Sensor Removal-Help Quickly
    By TCO in forum General Tech Discussion
    Last Post: 11-08-2008, 08:36 PM
  4. I found my first car... now i'm depressed... 56k take a nap!
    By Iron Indian in forum Off Topic Discussion
    Last Post: 06-24-2008, 11:13 PM
