Thread: 98 GTP will not start without fluid
Results 1 to 9 of 9
  1. #1 98 GTP will not start without fluid
    Apr 2013
    Cleburne, TX
    Recently bought a 98 GTP that was throwing 18 codes. I replaced the map, maf, plugs, wires, coils, ignition module, TPS, and cleaned air idle valve. Then I only had 4 codes: TPS performance, TPS low voltage (remember, TPS is NEW), misfire on 3, and maf. I checked the voltage values on TPS and it is good. Checked compression and spark on 3 and they are good. Checked injector 3 and 6, and 3 doesn't cause the engine to go down quite as much. Changed maf with a another running car. Checked fuel pressure and had 40 psi. It got 22 mpg on a trip over the weekend. Finally, I bought a ECM flashed to my car. No change. I still have to hit it with fluid to get it running. It also, idles up and down. Any ideas?
  2. #2 Re: 98 GTP will not start without fluid
    Omaha, NE
    Have you checked for a vac leak?
  3. #3 Re: 98 GTP will not start without fluid
    Apr 2013
    Cleburne, TX
    yes, a few times
  4. #4 Re: 98 GTP will not start without fluid
    Did you do an initial prime and bleed down test? Almost sounds like the pump or regulator aren't allowing enough pressure at key on for the prime to enter the cylinders.
  5. #5 Re: 98 GTP will not start without fluid
    Apr 2013
    Cleburne, TX
    I have not tried that. How do I do it?
  6. #6 Re: 98 GTP will not start without fluid
    Hook up the gauge, turn the key a few times and purge the air out. Then let it sit for say an hour or so.. Turn the key on and watch the pressure. GM says it should hold the pressure for 10 min. I have a feeling you'll find that when the key is initially turned..you aren't getting enough pressure.
  7. #7 Re: 98 GTP will not start without fluid
    Apr 2013
    Cleburne, TX
    I tried it, and I had 50 psi everytime I hit the key. After a few seconds, it would drop to 40 after the pump turned off
  8. #8 Re: 98 GTP will not start without fluid
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    gotta let it sit for 10 mins before you test it after priming.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  9. #9 Re: 98 GTP will not start without fluid
    Apr 2013
    Cleburne, TX
    With the key on or off? And, what am I looking for? I may have not understood you the first time. thanks
  1. There's trans fluid everywhere!!
    By FuglyGTP in forum General Tech Discussion
    Last Post: 09-05-2009, 05:08 PM
  2. How much fluid do i need? Thanks
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2009, 07:50 PM
  3. Fluid
    By BwolfGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-16-2009, 11:11 PM
  4. Trans. Fluid?
    By BwolfGT in forum General Tech Discussion
    Last Post: 04-11-2009, 05:26 PM
  5. How much fluid does the s/c take?
    By brodyman in forum General Tech Discussion
    Last Post: 09-17-2008, 02:15 PM
