Thread: Stalling
Results 1 to 5 of 5
  1. #1 Stalling
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    i raced my friends compg and beat him.... anyways after the race (4 pulls) when driving home i started to notice some weird trans shifts(rebuilt trans 5k miles ago).. from first to second under very light acceleration and it would shift at 4k rpm and my leggo meter was stuck with 3 notches lit up... so i pulled over and restarted my car and the leggo meter went back to normal then close to my friends house my car stalls. i stop and then restart it.. i then pull into his driveway and pop the hood.. i find out the vacuum t underneath the s/c snout was off.. so i reconnected the T and it has a small crack on the hose where it goes onto the T...these are different T's as i thought i had a leak there but i replaced them. then i started heading home.. the car ran fine and shifted fine no codes and the mileage was fine( i cleared the DTC to see if it had any major effect) then about 3 miles away from his house my car stalls again and i pull over to see whats up. it was running a little rough and then turned out fine and could see nothing visibly wrong. i then drove home and it ran perfectly fine. So.... is there anything to worry about? could that leak be the cause of it stalling? if not what could be the problem. im going to the junkyard tomorrow so i could get some things if needed..
    Thanks alot,
    Chris
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  2. #2 Re: Stalling
    I live here. DirtDog's Avatar
    Jun 2012
    Yes a vacuum leak could cause it to stall out. When I did a seafoam treatment on my old 04 I had to have someone sit on the gas to keep it from dieing out once I took the vac line off to pour into
  3. #3 Re: Stalling
    Jun 2012
    Illinois
    Alright thanks could that leak also be the culprit of the shifting problem?
  4. #4 Re: Stalling
    Jun 2012
    Quote Originally Posted by chris99gtp View Post
    That I dunno. One of the car smarts people will have to answer that one
  5. #5 Re: Stalling
    Jun 2012
    Illinois
    As of today car shifted fine so maybe it was the leak
  1. Stalling?
    By 98gtpzzp in forum General Tech Discussion
    Last Post: 11-24-2011, 04:01 AM
  2. stalling out
    By magician in forum Introductions/Noob Questions
    Last Post: 04-16-2010, 07:19 AM
  3. stalling 99
    By kent jordan in forum General Tech Discussion
    Last Post: 05-02-2009, 11:40 PM
  4. stalling
    By gnjim in forum General Tech Discussion
    Last Post: 01-04-2009, 11:47 AM
  5. Car keeps stalling out
    By SD GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 07:43 PM
