Thread: possible wheel bearing?
Results 1 to 13 of 13
  1. #1 possible wheel bearing?
    May 2012
    Cedar Rapids, Iowa
    Ive got a noise emitting from the front end. When I swerve left its quiet when I swerve right its louder. Would it be the passenger side one?
  2. #2 Re: possible wheel bearing?
    Yeah, its the passenger side, you took the load off it, thus the noise stopped.
  3. #3 Re: possible wheel bearing?
    I live here. DirtDog's Avatar
    Jun 2012
    I thought when u turned left weight went onto passenger side and off the drivers side but when u turn right weight goes on drivers side and off passenger
  4. #4 Re: possible wheel bearing?
    I gots my rights and lefts mixed up.
    Its your drivers side if the sound goes away going to the left.
  5. #5 Re: possible wheel bearing?
    Jun 2012
    Shew I thought I had been doing things all wrong when I read that
  6. #6 Re: possible wheel bearing?
    May 2012
    Cedar Rapids, Iowa
    Okay could the bearing be bad even if there is no play? Like I grab the tire and its solid.
  7. #7 Re: possible wheel bearing?
    Jun 2012
    Yea mine actually was on my gxp. The bearing had no play but fell apart when I took it out.
  8. #8 Re: possible wheel bearing?
    Sep 2011
    MI
    i'd put it on jackstands withe the wheels off the ground and have someone spin it up. slide under with an automotive stethoscope and listen to each wheel bearing. I've had a few that you're 100% sure its one side while driving and find its the other once its in the air. never hurts to double check... save having to buy a customer a new wheel bearing cause you screwed up.
  9. #9 Re: possible wheel bearing?
    Quote Originally Posted by 99PontiacGTP View Post
    Its way quicker to just grab the spring on the strut and feel for a vibration while spinning it, but either way works.
  10. #10 Re: possible wheel bearing?
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    Just replace both front ones. The other one is gonna go bad eventually.
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
  11. #11 Re: possible wheel bearing?
    Jun 2012
    Quote Originally Posted by Neil98gt View Post
    I agree with his statement. Cause I replaced one once then a month or so later the other one needed replacing
  12. #12 Re: possible wheel bearing?
    SE Level Member Jake U's Avatar
    Apr 2013
    Waukesha, WI
    How difficult is it to replace a wheel bearing. I have decent mechanical skills, but would it be worth taking it to a shop to have one replaced?
  13. #13 Re: possible wheel bearing?
    Jun 2012
    Its pretty simple. Just make sure u brake the end nut on the CV half shaft loose either with an impact or while the wheel is still sitting on the ground. Other than that you'll save ur self a lot of money diy.
  1. going on 4th Wheel Bearing
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 05-16-2014, 04:24 PM
  2. Wheel bearing or other?
    By Pointman in forum Brakes/Suspension/Chassis
    Last Post: 08-22-2011, 11:36 AM
  3. wheel bearing hub
    By learnAsUGo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2011, 09:43 AM
  4. Possible bad wheel bearing?
    By Cail in forum General Tech Discussion
    Last Post: 09-01-2010, 12:32 PM
