Thread: Third brake light works, everything else in the back is dead.
Results 1 to 2 of 2
  1. #1 Third brake light works, everything else in the back is dead.
    Mar 2013
    United States
    Tried searching through the forums, but didn't see anything that sounded like it fit my situation. I've got a 99 Grand Prix, and for a while now, my third brake light has been the only light in the back that's worked. I've replaced the bulbs, but obviously the problem is something else. I've been trying to find a wiring diagram or find out which fuse is linked to those circuits, but haven't had any luck. Could someone point me in the right direction?
    Thanks.
  2. #2 Re: Third brake light works, everything else in the back is dead.
    I live here. TLSheff's Avatar
    If it was me I would go through and pull/test each fuse just to make sure none are busted.
    Does any of the tail lights work?
    Brake lights when pedal pushed?
    Turn signals or Hazards?
    If none of it works I would suspect either a fuse or a ground/connection problem.
  1. Battery dead, AGAIN. ABS light on + other elec issues
    By The Chad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2013, 08:10 PM
  2. phil's build thread... back from the dead yet again
    By Poil336 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-18-2012, 08:50 PM
  3. Replies: 29
    Last Post: 01-21-2012, 07:57 PM
  4. Back from the dead. Need less boost!
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2009, 09:32 PM
  5. Help Car running rough SES light MAF dead
    By RNUOVR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 07:25 PM
