Thread: Stock intake valve versus 1.9 intake valve...worth it?!
Results 1 to 8 of 8
slimguns Stock intake valve versus 1.9... 03-30-2013, 03:01 AM
jlgp2007nc Re: Stock intake valve versus... 03-30-2013, 07:41 AM
slimguns Re: Stock intake valve versus... 03-30-2013, 11:31 AM
jlgp2007nc Re: Stock intake valve versus... 03-30-2013, 11:59 AM
GTPpower Re: Stock intake valve versus... 03-30-2013, 02:30 PM
jlgp2007nc Re: Stock intake valve versus... 03-30-2013, 02:40 PM
slimguns Re: Stock intake valve versus... 03-30-2013, 05:18 PM
slimguns Re: Stock intake valve versus... 03-30-2013, 03:34 PM
  1. #1 Stock intake valve versus 1.9 intake valve...worth it?!
    May 2012
    Albuquerque, NM
    Hello guys. I'm about ready for my top swap but plan on having some head work done first. They'll undergo a P&P job, SS valves, new seals, new locks, modified retainers, roller rockers, and upgraded springs to match the other mods. Where the question comes in is, is it worth it to upgrade from stock size intake valves to a 1.9 valve? How much difference does it make? Is it just help HP, or does it kill any KR too (hoping)?
    Please give me what you got.
    TIA,
    Slim
  2. #2 Re: Stock intake valve versus 1.9 intake valve...worth it?!
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Doing a cam with all of those flow mods?
  3. #3 Re: Stock intake valve versus 1.9 intake valve...worth it?!
    May 2012
    Albuquerque, NM
    Yes sir. Thinking the Intense S1. Other mods are or will be headers (including d-pipe), N*, LQ4, CAI, P&P M90, S2 IC, P&P LIM. I think that is it. That's off the top of my head but I believe that's it. I know they all support each other but I wanted to know if the .1" is worth the money since the heads are out and going to the shop already for the P&P.Slim
  4. #4 Re: Stock intake valve versus 1.9 intake valve...worth it?!
    Sep 2012
    North Carolina
    Then Yeah I'm sure you'll see crazy numbers, but you'll probably need a really small pulley on the blower to really get the most out of it. If it's a full blown race car then go for it. DD car...thennnnn get ready to fill up a couple times a week If you can't behave lol. Lot of flow needs a lot of fuel. Someone will correct If I'm wrong or left anything out.
    Best of luck with your build either way you go bud.
  5. #5 Re: Stock intake valve versus 1.9 intake valve...worth it?!
    May 2008
    Schuyler, NE
    You won't gain much on that setup with bigger valves.
  6. #6 Re: Stock intake valve versus 1.9 intake valve...worth it?!
    Sep 2012
    North Carolina
    See? Lol. Need to have something forcing more air through the engine yo make all of those mods worth the time and money. Smaller and smaller pullies or turbo.
  7. #7 Re: Stock intake valve versus 1.9 intake valve...worth it?!
    May 2012
    Albuquerque, NM
    I just thought about this. Are you talking 15-20+lbs or closer to 10-13? I know I can only really drop to a 2.8 before I just start making hot air. At 5500" altitude I wonder what a 2.8 would net....hum?
  8. #8 Re: Stock intake valve versus 1.9 intake valve...worth it?!
    May 2012
    Albuquerque, NM
    I was going to start with a 3.0 pulley. Figured that'd be a good start. I'd tune until happy, drop/tune, and so on. It's not a race car but I like to have the power in reserve. It's like concealed carry. ;-)
    mi doubt I'll be pushing it too hard but it will be something to occasionally whoop the rice burners on occasion.
    GTPpower, what type of set ups are the larger valves for? I "guessed" any higher boost car would benefit. Again, I guessed though.
  1. Replies: 26
    Last Post: 08-30-2012, 04:50 PM
  2. painting valve covers/intake
    By GOINDEF in forum Visual/Body Modifications
    Last Post: 06-23-2011, 08:58 AM
  3. valve cover gasket? intake gaskets?
    By bross in forum General Tech Discussion
    Last Post: 12-17-2009, 01:16 AM
  4. Looking for valve cover/intake install help in VA.
    By Deezul_AwT in forum Southeast
    Last Post: 03-18-2008, 11:00 AM
