Thread: Is there a threshold in modding where spark plug gap should be reduced from factory ?
Results 1 to 10 of 10
  1. #1 Is there a threshold in modding where spark plug gap should be reduced from factory ?
    Feb 2013
    Ohio
    Any experience closing spark plug gap after light mods ?
  2. #2 Re: Is there a threshold in modding where spark plug gap should be reduced from facto
    Don't do it. Run the gap at .055ish
  3. #3 Re: Is there a threshold in modding where spark plug gap should be reduced from facto
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    ....x2
  4. #4 Re: Is there a threshold in modding where spark plug gap should be reduced from facto
    Yes, at some point there is a need to reduce the gap because it can be blown out.
    You'd be at a pretty high power level to be needing to run anything under a .050 to .055 gap.
  5. #5 Re: Is there a threshold in modding where spark plug gap should be reduced from facto
    Florida
    Roughly around the point where the supercharger turns into a turbocharger.
    Or you're running a nasty blower setup/nitrous and need to close the gap some to prevent blowout.
    Light mods no need to mess with gap at all.
  6. #6 Re: Is there a threshold in modding where spark plug gap should be reduced from facto
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    What gap would you guys recommend for a build with XP Cam, Double Roller, Stage 2 ported heads, Gen v, 3.0 pulley, SD Headers, lQ4 MAF, FS I/C?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  7. #7 Re: Is there a threshold in modding where spark plug gap should be reduced from facto
  8. #8 Re: Is there a threshold in modding where spark plug gap should be reduced from facto
    Bowie, MD
    I usually do .054 so ill try. 055
    Sent from my SGH-T989 using Tapatalk 2
  9. #9 Re: Is there a threshold in modding where spark plug gap should be reduced from facto
    i wouldnt recommend it to anyone to be like me, but when i was running smaller pulleys i just gapped it at 0.045" and stopped caring.
  10. #10 Re: Is there a threshold in modding where spark plug gap should be reduced from facto
    Feb 2009
    flintnasty MI
    close the gap if you start to misfire or lean it back out until it stops misfiring.
    I run down to a 025 gap on the cheapo plugs to keep my turbo setup happy, so you can do it if you want.. it doesnt really hurt.
  1. Spark Plug Gap
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 10-14-2012, 09:57 AM
  2. which spark plug?
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2012, 07:39 PM
  3. The best spark plug for a 04 gt ???
    By PALMCASTER GT1 in forum General Tech Discussion
    Last Post: 11-16-2011, 10:05 PM
  4. Spark plug
    By zildjian102 in forum General Tech Discussion
    Last Post: 03-01-2011, 02:48 AM
  5. Spark Plug Help
    By STP5593 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 10:15 PM
