Thread: Electrical power cuts out
Results 1 to 4 of 4
  1. #1 Electrical power cuts out
    Dec 2011
    Kingston ON
    While my engine is running my lights will turn off briefly as well my gauges for fuel, oil life etc will turn off. It does not seem as though I am losing engine power though. My heat also died at the same time a couple of times but the last time the power cut out the heat stayed on. I had my hood up the last time this occurred and it stated making an odd side from the side where my belts are located but I could not pinpoint where it was coming from as it only lasted a few seconds. My battery is new this year and I ensured that my alternator is charging the battery using a multimeter. Any thoughts?
    Its a 2002 Grand Prix GTP 3800. No mods!
  2. #2 Re: Electrical power cuts out
    SE Level Member falcongt's Avatar
    Mar 2013
    Moulton, Al
    I would check all major wire connections (battery, starter, alt, ect) for corrosion and tight connections. I would check ALL fuses inside and under hood to make sure non is blown but also to make sure they are fully seated and not flopping around. I would also wiggle the ignition key the next time it happens. It sounds to me like something is loose.
    Hollis Armstrong
    2002 Grand Prix GTP
  3. #3 Re: Electrical power cuts out
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    I had a problem:
    Radio cut off, windows quit working, gauges quit working, lights would cut off when I hit the brake, other weird stuff.....
    I purchased an ignition switch because all symptoms lead to that. Before I installed it I checked my battery, I pulled the positive terminal off and it was gummed up. I cleaned it all worked fine. If all your stuff is new, maybe something didn't get tightened down. If you are hearing "sounds" around your belt area (beside your battery) you may have arching at the terminals. But as falcon said, check terminals, grounds, the lead to your alternator, ect..
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  4. #4 Re: Electrical power cuts out
    Dec 2011
    Kingston ON
    I will go ahead and check the things that you pointed out, I just don't have the time now as I'm heading out of town.
    Another symptom that I just noticed is when I turn on my A/C my lights turn off, when I turn the A/C off , my lights come back on!
  1. Need help, engines cuts off
    By Sudden in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-11-2012, 01:25 PM
  2. Electrical Problem? No Power..
    By Nic22 in forum General Grand Prix Discussion
    Last Post: 08-13-2012, 05:57 AM
  3. electrical power loss some were
    By erice in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-30-2012, 08:04 AM
  4. power window slash electrical question
    By SlowPurpleGTP in forum General Tech Discussion
    Last Post: 06-22-2008, 09:25 PM
  5. Electrical Power Loss
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 06-17-2008, 07:40 PM
