Thread: 2005 Pontiac Grand Prix GXP needs jump to start after trans replaced
Results 1 to 6 of 6
  1. #1 2005 Pontiac Grand Prix GXP needs jump to start after trans replaced
    Jul 2010
    Indiana
    Ok so I just took my car in to get the trans replaced and the trans shop did that and sent it back to my grandpas shop where I took it in, but apparently they screwed something up and now my car wont start without a jump. They just sent it back to the trans shop to get checked out, but any ideas as to what the problem could be? This is majorly inconveniencing me, i need this fixed ASAP.
  2. #2 Re: 2005 Pontiac Grand Prix GXP needs jump to start after trans replaced
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Batteries do go bad for no apparent reason just so your aware of that...
    Or they left your key on and drained it completely and then blamo bad battery especially if it's older.
    Verify it's charging once running, but if you have to jump it when you know charging is fine the battery is toast
    Very unlikely the starter wasn't installed correctly
    Possible bad ground on the block?
    Just throwing some ideas out there
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: 2005 Pontiac Grand Prix GXP needs jump to start after trans replaced
    Jul 2010
    Indiana
    Quote Originally Posted by rperry435 View Post
    The battery isn't that old and i noticed no signs of it failing. I don't have the car rignt now so Im just going off what my grandpa is telling me but it sounds more like whatever is wrong has to do with the new trans installed. I doubt its coincidental it just started doing this after being installed considering it started fine before. But i dunno, I'm far from a car expert, I'm just hoping to maybe figure out something the mechanics missed so i can get them on the right track and get my car back.
  4. #4 Re: 2005 Pontiac Grand Prix GXP needs jump to start after trans replaced
    Yoga city
    have you check the voltage even at the batt to confirm issues? I would second bad connection(ground) on teh block near starter.
  5. #5 Re: 2005 Pontiac Grand Prix GXP needs jump to start after trans replaced
    Jul 2010
    Indiana
    Well apparently they called GM and discovered that some module inside the trans wasn't programmed correctly. apparently it was showing it in gear even when it was in park and thats what was causing the car not to start. Thats what I was told anyways. They have to take it out now and fix it lol but I should have it back in a day or two at least.
  6. #6 Re: 2005 Pontiac Grand Prix GXP needs jump to start after trans replaced
    Oct 2011
    MI
    Ahh the joys of taking it to a shop :beer:
  1. Help. 2005 Grand Prix heater blower doesn't work on remote start.
    By billydomud in forum General Tech Discussion
    Last Post: 01-20-2013, 08:55 PM
  2. 1995 Grand Prix - Intermittent start - Needles jump oddly
    By Beat Club in forum General Grand Prix Discussion
    Last Post: 03-12-2012, 11:02 AM
  3. 2005 grand prix wont start
    By racer8688 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2010, 03:18 PM
  4. 2005 grand prix gxp trans
    By guy87 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-01-2009, 11:06 PM
