Thread: Electrical system problem?
Results 1 to 3 of 3
  1. #1 Electrical system problem?
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    So I was starting to leave my familys house from easter and when I started my car my tach, fuel, engine temp, aeroforce gauges did not work, traction control off message came on, low fuel message came on, and my cars miles read "ERROR MI". This has happened about three or four times now and I have no clue why it happens. The car will drive perfectly normal when this is going on. My radio, speedo, lights, ect will work perfectly just what I described will not work. If I shut off the car and restart it everything will go back to working again. Anyone know what could be going on? My aeroforce gauge always says my battery volts are anywhere from 14.9 to 14.2 or 3. Thanks in advance!
  2. #2 Re: Electrical system problem?
    Oct 2011
    huntley
    Anyone?
  3. #3 Re: Electrical system problem?
    St. Louis
    Remove and clean your battery cables, and clean the grounds that are on the transmission bolt and see if that takes care of it. The only other thing that comes to mind would be an ignition switch.
  1. Replies: 4
    Last Post: 11-03-2011, 08:03 AM
  2. Electrical problem
    By rocket69GTP in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2011, 10:29 AM
  3. Gran Prix electrical system.
    By wallyg33 in forum Introductions/Noob Questions
    Last Post: 02-05-2011, 10:43 AM
  4. Anti lock brake system electrical schematic?
    By thirdgenfcarnut in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2009, 03:00 PM
  5. Help please!!! Electrical system acting weird, Car won't start now!!
    By Tkuligowski in forum General Tech Discussion
    Last Post: 01-24-2008, 08:42 PM
