Thread: New(to me) heads, clean them or no?
Results 1 to 12 of 12
  1. #1 New(to me) heads, clean them or no?
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    So I just bought some used heads and they are pretty dirty on the inside, what is the best way to clean them? Or should I not clean them and just put them in the car as they are? I don't think that is the right idea so that is why I am coming to you guys for some advice! Thanks for the help in advance
  2. #2 Re: New(to me) heads, clean them or no?
    Local machine shop just uses brake parts cleaner when he cleans the heads or blocks.
    04 Comp G.
  3. #3 Re: New(to me) heads, clean them or no?
    GT Level Member SleeperGS's Avatar
    Dec 2010
    Cincinnati, Ohio
    I would hone
  4. #4 Re: New(to me) heads, clean them or no?
    Dec 2010
    Cincinnati, Ohio
    there is also a solution for them to be dipped in if done properly.
  5. #5 Re: New(to me) heads, clean them or no?
    Ohio
    I put my heads in my parts washer. I use a mix of kerosene and diesel. 3-4 gallons of each
  6. #6 Re: New(to me) heads, clean them or no?
    Oct 2011
    huntley
    Hmm I think I am just going to hose them down with brake cleaner, should be the easiest thing for me to do
  7. #7 Re: New(to me) heads, clean them or no?
    and cheapest
    04 Comp G.
  8. #8 Re: New(to me) heads, clean them or no?
    May 2008
    Schuyler, NE
    I would take them to a machine shop and have them hot tanked.
  9. #9 Re: New(to me) heads, clean them or no?
    Jan 2013
    Tn
    Did mine with some brake cleaner and a scrub brush the sanded and painted the outsides with high temp paint
  10. #10 Re: New(to me) heads, clean them or no?
    I used super clean then went to town with the eastwood porting kit.
    But hot tank and a pressure test would be ideal.
  11. #11 Re: New(to me) heads, clean them or no?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Call a local machine shop and see how much they charge to recondition them. Would be worth it, plus you'd have a perfectly smooth mating surface for gaskets. These heads have been on another car which was heated, cooled, heated, cooled, ect... Even though they are not aluminum, I'd still have them checked.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  12. #12 Re: New(to me) heads, clean them or no?
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    if your not taking them apart becarefull how you clean them, if you get too much water/solvents in the guides you could sieze the valve a few minutes after fire up
    if your not going to spend much money on the heads, i would take them apart, clean with porting bits/cartridge rolls (die grinder), take your valves to a shop and have them grind them (cheap) then take them home and lap them in yourself, assemble with gear oil (140w) if you have it lying around
    or just bolt them bitc*es on
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  1. Help on crack heads..need advice on l26 heads
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2013, 10:07 AM
  2. Clean up
    By Dthreap in forum Buy/Sell Other/Misc
    Last Post: 07-02-2012, 04:40 PM
  3. ZZP Heads VS Intense Heads
    By PurpleGuy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 07:57 AM
  4. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
