Thread: Driver Information Center
Results 1 to 6 of 6
SuperSE Driver Information Center 03-16-2013, 02:01 PM
Logan541 Re: Driver Information Center 03-16-2013, 03:06 PM
SuperSE Re: Driver Information Center 03-17-2013, 12:58 PM
Logan541 Re: Driver Information Center 03-17-2013, 09:30 PM
SuperSE Re: Driver Information Center 03-19-2013, 11:40 AM
Logan541 Re: Driver Information Center 03-20-2013, 05:40 PM
  1. #1 Driver Information Center
    Mar 2013
    Grand Rapids, MI
    I have a 2002 Grand Prix and it was too slow, so I did the swap It is way better with my 3800 supercharged engine. Everything went pretty good, just a few bugs to work out. I purchased a totaled 99 and used the engine and tranny for my car and brought the pcm over from the old car. I am having trouble with my driver information center, I brought it over from the 99. The main part with the boost gauge and all that other stuff works fine. The traction control lights are doing some goofy things. Every time I turn on the car, the low trac light comes on for a second and then the tcs off light comes on. It does this every time I turn on the car. If I push the tcs button it does turn off the light and turn the traction control back on, but it does not matter after I turn the car off, goes right back to tcs off. I believe I wired it up correctly and I don't think that is the problem Any thoughts? Larry
  2. #2 Re: Driver Information Center
    Feb 2010
    TN
    You sure it was working in the other car before you moved it?
  3. #3 Re: Driver Information Center
    Mar 2013
    Grand Rapids, MI
    I do not know, did not have a chance to check it before it was switched.
  4. #4 Re: Driver Information Center
    Feb 2010
    TN
    ahh you may want to investigate that aspect of it could have fried PartsLady has one for sale if you need it hit her up
  5. #5 Re: Driver Information Center
    Mar 2013
    Grand Rapids, MI
    Is there any way to test it? I would hate to spend a lot of money something then have it not fix it.
  6. #6 Re: Driver Information Center
    Feb 2010
    TN
    Only way I hae tested them have been by swapping it with a known good one
  1. 97 GTP driver or information center (DIC)
    By JB122894 in forum Wanted To Buy - Parts
    Last Post: 03-21-2013, 07:54 PM
  2. Dim Driver Information Center
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 02-13-2012, 09:25 PM
  3. driver information center
    By bc1 in forum General Tech Discussion
    Last Post: 12-12-2010, 10:21 AM
  4. Driver information center
    By sbrutcher in forum Introductions/Noob Questions
    Last Post: 02-13-2010, 03:20 PM
  5. driver information center
    By Green Machine in forum General Tech Discussion
    Last Post: 08-05-2008, 12:14 AM
