Thread: Code P1629 and Code P1573
Results 1 to 3 of 3
  1. #1 Code P1629 and Code P1573
    Mar 2013
    Michigan
    I have a question for all of you! My 1998 pontiac grand prix gtp supercharged is starting and stalling after 3-4 seconds, however you can get it to run if you crank it 4-5 times. We put it on the machine, and got Codes p1629 and P1573. I am at a loss at what this could be because in Dec,2012 I had the aftermarket security/remote starter removed and a new remote starter put in, no security. This has been going on for about a year and a half, with the car starting and stalling 3 seconds later whenever it wants to. Any ideas? In January I also had the key tumbler replaced because it was broken. This is still happening.
  2. #2 Re: Code P1629 and Code P1573
    the first code is security like you said, you can have that tuned out with a tuning program. you would need a local with a tuner to do that. or go to a dealer to fix it.
    the 2 nd code i found this thread, Grand Prixs Of North America • View topic - P1573 could be more bad wires or the ecbm is bad. a abs scan would tell more where to look. that scan you need to go a shop to have done, and most will charge you to scan the car. but its better then just guessing and tossing money at it.
  3. #3 Re: Code P1629 and Code P1573
    Mar 2013
    Michigan
    Thanks, I will be checking that out!
  1. bad idle maf code driver 6 line 4 code
    By GTPSHAWTY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2012, 05:56 PM
  2. '99 Grand Prix GT has code 1810, yet runs great as always, so why the code?
    By McFly1999 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 07:52 AM
  3. code
    By Jedi in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-17-2011, 12:11 PM
  4. does anyone know how to fix this code?
    By shsfootball57 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2011, 12:33 PM
  5. Code p1573 after EBTCM replacement
    By xxmattfxx in forum General Tech Discussion
    Last Post: 09-18-2009, 08:52 PM
