Thread: Top swapped L26 owners...
Results 1 to 20 of 29
  1. #1 Top swapped L26 owners...
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    All who've successfully top swapped the L26 and ran with the higher compression...Having g problems with pre det and knock all the time? I'm >< that close to throwing it together...
  2. #2 Re: Top swapped L26 owners...
    with the right tune and other parts in the motor...you should be fine. tons of people have done it.
  3. #3 Re: Top swapped L26 owners...
    What I want to know is...
    A little info...
    For those that have top swapped L26's, has anyone used a GenIII blower? I know the obvious and easy choice would be the Fiver...but this top swap is basically gonna cost shipping...guessing custom 4 to 3 bolt adapter plate to make it work?
  4. #4 Re: Top swapped L26 owners...
    London Ont, Canada
    thats a good question bluegai
  5. #5 Re: Top swapped L26 owners...
    imjustsayinclosetmonkey...
  6. #6 Re: Top swapped L26 owners...
    Sep 2012
    North Carolina
    Well I have another post up with my list somewhere lol. But
    stock block
    Gen v with 4.0 and 3.4 pulleys
    42.5 inj
    1.8 rockers
    Intense pushrods
    105 springs
    HP tuners
    LQ4. Maf
    And most of the obvious little stuff...
  7. #7 Re: Top swapped L26 owners...
    Donating Users akarana23's Avatar
    West Bloomfield, MI
    Quote Originally Posted by blueguy91 View Post
    I run a GenIII on an L26 block
  8. #8 Re: Top swapped L26 owners...
    Quote Originally Posted by akarana23 View Post
    But not in an '04+ car
    Hence the four bolt TB adapter comment...
  9. #9 Re: Top swapped L26 owners...
    Sep 2012
    North Carolina
    Haha yeah 07 here.
  10. #10 Re: Top swapped L26 owners...
    West Bloomfield, MI
    Oh lmao didn't read that thoroughly, my bad
  11. #11 Re: Top swapped L26 owners...
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    this doesnt belong in the build thread section...
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  12. #12 Re: Top swapped L26 owners...
    Sep 2012
    North Carolina
    My apologies
  13. #13 Re: Top swapped L26 owners...
    Moving...
  14. #14 Re: Top swapped L26 owners...
    Feb 2009
    flintnasty MI
    Quote Originally Posted by jlgp2007nc View Post
    stock block
    42.5 inj
    1.8 rockers
    Intense pushrods
    105 springs
    HP tuners
    LQ4. Maf
    You would never be able to run a 3.4 withou a cam or intercooler.
    Upgraded injectors are not needed for quite awhile.. 3.2 pulley or better.
    1.8 rockers are no better than stock rockers.
    Pushrods are pointless.
    The stock 04 maf works fine.
  15. #15 Re: Top swapped L26 owners...
    Sep 2012
    North Carolina
    Short and sweet. Thanks. Now I can move some money around.
  16. #16 Re: Top swapped L26 owners...
    London Ont, Canada
    DH, any experience mating a 04+ TB to the Gen3 tho?
  17. #17 Re: Top swapped L26 owners...
    Feb 2009
    flintnasty MI
    Done it in reverse a few times with the turbo stuff running a L26.. the adapter is pretty easy, but I would probably plan on porting the gen3 inlet to match the bigger TB.
  18. #18 Re: Top swapped L26 owners...
    Feb 2008
    I'm not 100% sure about this, but could you drill and tap your own mounting holes? No adapter necessary if you can do it that way.
    Sent from my SkyRocket
  19. #19 Re: Top swapped L26 owners...
    Feb 2009
    flintnasty MI
    Quote Originally Posted by DanGTP View Post
    no ....
  20. #20 Re: Top swapped L26 owners...
    Feb 2009
    flintnasty MI
    How many 04+ cars have you tuned again?
  1. 98 GP GT L67 swapped needs pcm which one??
    By 98PONTIAC in forum General Tech Discussion
    Last Post: 12-27-2012, 03:14 PM
  2. Top swapped
    By Dragon1972 in forum PCM Tuning
    Last Post: 05-03-2012, 09:07 AM
  3. Swapped 05 L32 into an 04 L26 HELP???
    By lambokit in forum General Tech Discussion
    Last Post: 04-20-2011, 07:32 PM
  4. L67 Swapped
    By 99LuminaLSC in forum Chevrolet Lumina
    Last Post: 12-15-2007, 08:57 AM
