Thread: Engine Removal: Should I pull the engine or drop the sub frame?
Results 1 to 4 of 4
  1. #1 Engine Removal: Should I pull the engine or drop the sub frame?
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    I need to pull the trans to deliver to someone for an overhaul and install a cam in my car.
    With this I was going to remove both item from the car. I would like to know if I should go about pulling from the top or dropping out of the bottom. Which is easier?
    Yes I know i could remove the trans and do the cam with the engine in the car, no i do not chose that option
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: Engine Removal: Should I pull the engine or drop the sub frame?
    for just the trans. Mr Boost had my old tranny out in 1.5 hrs.
    but for a engine trans, maybe pulling it all out the top is better.
  3. #3 Re: Engine Removal: Should I pull the engine or drop the sub frame?
    Mr. Boost has a write up detailing his favored way of pulling both at once.
    Both can come out the top together almost faster than a trans can drop out the bottom by itself.
  4. #4 Re: Engine Removal: Should I pull the engine or drop the sub frame?
    I wish I had a hoist to pull mine out the top. It's out the bottom for me.
  1. How to pull an engine: BillBoost Style
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 04-12-2020, 04:12 PM
  2. How to pull and engine and transmission out the top
    Last Post: 12-06-2013, 09:52 PM
  3. Pull engine, trans or both
    By cogsracing in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-23-2011, 06:30 AM
  4. Engine and Trans pull... SAME TIME?
    By nathangartz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 09:40 PM
  5. pull engine?????
    By kingd44 in forum Off Topic Discussion
    Last Post: 08-10-2008, 09:12 PM
