Thread: Loud metal screech?
Results 1 to 7 of 7
  1. #1 Loud metal screech?
    SE Level Member MattGTP04's Avatar
    Jun 2014
    United States
    Hey guys, I'm not really sure if this is the right place, so I apologize if it's not.
    So recently, within the last week actually, I've started to notice something while driving my GP (04 GTP). Whenever I go to back up, a metal screeching or squealing comes from what I think the front drivers side wheel area. It lasts for about 5 seconds, then goes away. But it's every single time I go into reverse anywhere.
    I don't know if this could be connected to it, but after I back up and shift to drive again, as soon as I start to go forward I hear somewhat low groan that lasts about a second or two, in the same area.
    The guy I bought the car from said new brake pads were just installed, so do you think they could have been installed wrong in the front drivers wheel? You guys know the cars better than me. Any help appreciated. Thank you!
  2. #2 Re: Loud metal screech?
    I'd be checking them for sure.
  3. #3 Re: Loud metal screech?
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    Unless you have a lot of pressure applied to the brake pedal backing up, chances are it's not brakes,although you may want to make sure that caliper is tight. My guess check the wheel hub. Driving forward the bearings settle into a certain position. When you back up the bearing changes position. And when you go forward again the bearing moves back. If there is that much movement you need to check it soon before it ruins your axel or you have an accident.
  4. #4 Re: Loud metal screech?
    Lewis..how can you say that? What if a caliper bolt wiggled out (since brakes were just done) and the caliper is flipping up and scraping the inside of the rim? Then when he goes forward..it slides back down in place.
    Been there..seen it
  5. #5 Re: Loud metal screech?
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Check the metal plate that goes between the bearing and knuckle
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  6. #6 Re: Loud metal screech?
    ^^^ hahahahaha I know someone that did that too!
  7. #7 Re: Loud metal screech?
    Dec 2012
    Where 4T65E's were born
    My car did something like that. Makes a noise for the first few feet in reverse them stopped. It also did it on turns, but listen and see if its the same. It was my wheel bearing.
    http://youtu.be/gXSSyLOiuvU
    Sold.
  1. Super loud screech after music plays somewhat loud.....
    By rizer in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 03:08 AM
  2. supercharger screech
    By bps02gtp in forum General Tech Discussion
    Last Post: 11-15-2012, 11:48 PM
  3. Loud Metal Clanking sound
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2010, 02:05 PM
  4. tranny screech
    By GTP Ryan in forum General Tech Discussion
    Last Post: 04-30-2010, 11:43 PM
  5. rumble and screech 06 gxp monsoon
    By jpbarnz in forum Audio, Security & Visual Electronics
    Last Post: 01-28-2010, 10:29 AM
