Hey guys. I have a 2000 GT that is throwing a P0102 code symptoms are intermitently stalling and idle fluctuations. The stalling doesnt happen to ofted but is random, I could be driving down the street and it will stall or it could happen at a stop light. It starts back up fine with no problems though. I also need to have this car emissions tested and here in Ontario no codes are permitted. The MAF sensor looked pretty clean but I cleaned it with some MAF cleaner anyway. The MAF screen is clean. There are no blown fuses. I didn't check for voltage or frequency to the MAF because I dont have a tester that peirces the wire. I have read countless threads regarding This issue and there doesnt neem to be a specific solution. I don't want to spend $150+ on a new sensor and have it now be the problem. I unplugged the sensor and the idle issues remained, I didn't drive around with it unplugged though. I was told by a mechanic friend that it is likely to be a vaccum leak. I want to check for this today. Any help would be appreciated, If you had this problem resolved before, how did you do it? Was it the sensor? Vacuum leak? Something else?
