Thread: Leaking gas if pump is left on
Results 1 to 15 of 15
  1. #1 Leaking gas if pump is left on
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Please help me with this issue. If I leave the gas pump on, it will fill up, then leak under the car. It doesn't leak at the end of the neck, so there's gotta be a hole in the neck somewhere, would be my guess.
    I do have an emissions code, evap I believe (it's been a while since the car was scanned, CEL has always been on).
    Sure, I could just watch how much gas I'm at when filling up, but I want to get this fixed, which will also remove my CEL.
  2. #2 Re: Leaking gas if pump is left on
    Replace filler neck?
  3. #3 Re: Leaking gas if pump is left on
    Sep 2012
    Clarkston, MI
    I want to make sure that's the issue, I just need help with diagnosing it. I don't want to purposely overflow my gas at the gas station and go under my car with a light looking for the leak. LOL
  4. #4 Re: Leaking gas if pump is left on
    Can you get ahold of a smoke machine, those work the best for finding evap/vacuum leaks.
  5. #5 Re: Leaking gas if pump is left on
    Donating Users 1quikgp's Avatar
    Jan 2009
    Ohio
    Is it possibly leaking out of the top of the tank? Could be the fuel pump o-ring.
  6. #6 Re: Leaking gas if pump is left on
    Sep 2012
    Clarkston, MI
    Yes quik, that could be possible. I had to change the sending unit because my gauge wasn't working properly. I'll definitely look into that.
  7. #7 Re: Leaking gas if pump is left on
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    If you can't get a hold of a smoke machine. they happen to be sorta expensive. You can modify a Halloween fog machine. That's what I have done in the past. Although I cant say I know how good Halloween fog is for your car. It does work lol.
    I went NA when a whore left -$300 in my bank account.
  8. #8 Re: Leaking gas if pump is left on
    Sep 2012
    Clarkston, MI
    So it is my fuel pump assembly that isn't sealed to the tank, thus overflowing the tank when I fill all the way up. What should I do to seal it? RTV?
  9. #9 Re: Leaking gas if pump is left on
    Jan 2009
    Ohio
    There is supposed to be an o-ring that seals it. Sometimes it just slides down the pump.
  10. #10 Re: Leaking gas if pump is left on
    Remove the pump, get a new seal and put it back in.
  11. #11 Re: Leaking gas if pump is left on
    Whoa...do we wanna diagnose or shotgun parts?
    Where does the leak appear to be happening. Middle of the are or near the fuel tank door?
    Jack and support the back of the car. Pull the driverside tire. Remove the plastic wheel well and inspect the filler tube and the hoses to the tank.
    Look at the tank, does it appear fluid ran down the filler tube and dripped off the tank, only dripped off the tank..
    These are your indicators. No smoke machine is needed, a few basic tools and some decent eye sight is all.
  12. #12 Re: Leaking gas if pump is left on
    Sep 2012
    Clarkston, MI
    Quote Originally Posted by 1quikgp View Post
    I didn't notice an o-ring when I reinstalled the pump, it's a rubber o-ring, correct? It's possible I damaged it or it fell off but I can't be sure. I'll take a look once my tank is lower on gas, I just filled up.
    I filled up yesterday and looked on the ground and there was a lot of gas under the middle of the car. I'm going to check out the fill neck like you said because I guess that's also possible.
  13. #13 Re: Leaking gas if pump is left on
    Sep 2012
    Clarkston, MI
    Well, the filler neck is not leaking, there are no signs of leaks and I just made it leak yesterday, so that's ruled out. I'm still thinking it's the o-ring at the top of the tank. The gas pump will turn off after it leaks out a little bit under the car, so the leak is obviously near or at the top somewhere. My lines have never leaked either.
    @BillBoost37, look at what I found when investigating the neck:
    This is the evap canister isn't it? The big tube was not connected. Glad I went under there.
  14. #14 Re: Leaking gas if pump is left on
    Jan 2009
    Ohio
    Correct me if I'm wrong, but the first pic is a tank seal for 98-00, and second is 01-03... My 2000 did the same thing, the o-ring slid down the pump during install. The pump would click off after losing fuel out the top, but I did get a few extra miles that tank since it was completely full
  15. #15 Re: Leaking gas if pump is left on
    Sep 2012
    Clarkston, MI
    Ok excellent, that's probably it. It'll be a few days before I can do anything cause my tank is still full.
  1. Leaking coolant, even after replacing water pump
    By msnuser111 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-02-2015, 10:57 AM
  2. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
  3. 42.5# Injectors, Flowjet pump, ZZP pump controller
    By StamperGTP in forum For Sale - Parts
    Last Post: 01-10-2012, 02:33 PM
  4. Replies: 4
    Last Post: 06-20-2010, 04:04 PM
  5. replaced power steering pump and now it is squeeling and leaking badly! Help
    By Cheri in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2009, 08:10 AM
