Thread: wiper problem
Results 1 to 11 of 11
  1. #1 wiper problem
    Nov 2012
    Illinois
    I have a 2002 Grand prix gt that when you turn off the wipers they do not bed, instead they go up. Someone told me maybe a "park switch"? Any ideas, is this common? I just figured the arms needed to be taken off and then turn the switch on, and let it bed, and then hook up the arm again?
  2. #2 Re: wiper problem
    There is a little tab under the wiper that is bent. bend it back and enjoy
  3. #3 Re: wiper problem
    Nov 2012
    Illinois
    What does that tab do? Cause I mean, when you shut off the wipers, they go ALL the way up and are in line with the drivers vision. Does this tab prevent that?
  4. #4 Re: wiper problem
    The tab being bent back down tells the wiper trans where to park at.
  5. #5 Re: wiper problem
    Nov 2012
    Illinois
    I'll try that. thanks.
  6. #6 Re: wiper problem
    Aug 2008
    KCMO
    Did this work for you? I'm having the same problem as we speak.
  7. #7 Re: wiper problem
    Houston
    Yup, just bend this tab back
  8. #8 Re: wiper problem
    Aug 2008
    KCMO
    Do I just remove the cowl to access that?
  9. #9 Re: wiper problem
    Houston
    Yes. IIRC, you need to remove the wiper arm to remove the cowl
  10. #10 Re: wiper problem
    Aug 2008
    KCMO
    Driver side correct?
  11. #11 Re: wiper problem
    Houston
    Correct
  1. Wiper chatter problem
    By Coldwaves in forum General Grand Prix Discussion
    Last Post: 01-02-2013, 04:33 PM
  2. 02 Wiper Problem and many more
    By airjordan223 in forum General Tech Discussion
    Last Post: 06-24-2010, 01:14 PM
  3. 04 grandprix wiper problem
    By sasquatch094 in forum General Tech Discussion
    Last Post: 09-08-2009, 07:04 AM
  4. Wiper problem
    By mnkyspnk in forum General Tech Discussion
    Last Post: 08-28-2009, 01:16 PM
  5. Wiper problem again
    By Fish in forum Visual/Body Modifications
    Last Post: 02-01-2008, 03:22 PM
