Thread: HVAC Blower Question
Results 1 to 4 of 4
  1. #1 HVAC Blower Question
    SE Level Member 2001camaroB4C's Avatar
    Okay recently the blower for my hvac has stoped working. I thought it was the 5 speed switch so I took it apart and cleaned the contacts and it still doesnt work. Previously only the high setting worked. Then it started to work on and off and now nothing.
    I cant find any fuses for the hvac system. Is the fuse panel under the hood the only one on the car or is there another one?
    Any have any ideas about where I should start looking to fix this it is getting to where i need the heat and defrost.
    Also Im poor so if anyone has cheap ideas they would be greatly appriciated.
    2001 A4 Camaro B4C, 1.94 60ft - 8.48 1/8@84.13 - 13.17@104.29, should go faster with a better track and no ses light.
    And now a 98 Grand Prix
  2. #2 Re: HVAC Blower Question
    Oklahoma
    Moved to the correct section. I would also point out the rules, post #7 in the following thread:
    http://www.grandprixforums.net/f14/a...read-6828.html
  3. #3 Re: HVAC Blower Question
    Feb 2008
    If you blower works on 1 speed and its the highest speed, your problem is usually the blower motor resistor. It is located right next to the blower motor. Take it out and look at it, you will be able to tell if it is bad just by looking at it, if it looks like this: http://i266.photobucket.com/albums/i.../IMG_8118a.jpg, its probably your issue. Get one from a place like Auto Zone (part #DR783) they don't cost that much. Also it has been said that water is what damages these, so make sure your water deflector (located under the wiper cowl) has not fallen off.
    Blower motor resistor repair links:
    http://www.grandprixforums.net/f81/b...stor-6851.html
    http://www.grandprixforums.net/f81/t...stor-1350.html
    Window deflector repair links:
    http://www.grandprixforums.net/water_floorboard.php
    http://www.grandprixforums.net/f73/w...-fix-6961.html
    Good Luck!!
  4. #4 Re: HVAC Blower Question
    Quote Originally Posted by Blown97 View Post
    Good Luck!!
    Thanks, I always seem to find these things like seconds after i post the question.
  1. HVAC help
    By 3800SE in forum General Tech Discussion
    Last Post: 03-07-2010, 07:02 PM
  2. Another Blower Motor Question.
    By darylward in forum General Tech Discussion
    Last Post: 09-11-2009, 04:24 AM
  3. 97-03 Digital DIC & Digital HVAC Swap Question
    By StreetChariot in forum General Tech Discussion
    Last Post: 03-27-2008, 11:04 AM
  4. No hvac control
    By Onthebrinc in forum General Tech Discussion
    Last Post: 03-23-2008, 03:24 PM
  5. hvac control
    By Chleby in forum General Tech Discussion
    Last Post: 01-17-2008, 11:53 AM
