Thread: Car throwing CEL
Results 1 to 16 of 16
  1. #1 Car throwing CEL
    Palmdale
    I have a 2001 GTP that is acting funny. The car was running fine this morning. My wife goes to drive the car home and the CEL came on. She said the car was sputtering also the check engine liht flashes after you go over 35 . Took the car for a ride around the block to PEP Boy and had the codes ran.. I got P0306, P0137t ,P1133. My brother seems to think it is the O2 sensors. I got both 02 sensors. Has anyone else had theses issues?
  2. #2 Re: Car throwing CEL
    Omaha, NE
    Bank 1 is the o2 sensor upstream of the Cat. Since you aren't throwing any bank 2 codes, I wouldn't bother replacing the downstream o2.
    Make sure you don't get a splice in style 02 sensor.
    This still doesn't explain the miss on cyl 6. You may want to take a look at the plug, wire, coil pack and injector for that cylinder.
  3. #3 Re: Car throwing CEL
    Aug 2011
    Kenosha
    Quote Originally Posted by dmack976 View Post
    A quick google search says p0306 is cylinder 6 missfire. I have also found that in some people's cases (google) a missfire triggered p0137. I'd fix the missfire first and clear the codes to see if the other ones come back. If they do I would test your o2 sensors before just replacing them (or it) because it seems that doesn't always fix the issue.
  4. #4 Re: Car throwing CEL
    Aug 2011
    Kenosha
    ^ agreed. You could try swapping the #6 plug wire with a different Cyl and see if the missfire changes cylinders. You can also start the car at night and spray the spark plug wires and coils with water. (A fine mist from a spray bottle will do) then look for the wires/coils to ark.
  5. #5 Re: Car throwing CEL
    Palmdale
    well according to AutoZone P0306 The power train control module monitors the crankshaft speed and has detected a misfire condition.
    Probable cause:
    Ignition system fault-spark plug(s), ignition wires, coils
    Vacuum leak
    injector fault
    high or low fuel pressure
    It seems like both bank are throwing a code for 02 sensor. I guess my question would be does it makes sense that if both 02 sensor go out it would send a P0306?
  6. #6 Re: Car throwing CEL
    Aug 2011
    Kenosha
    I am new to the 3800 scene but I wouldn't think bad o2 sensors would cause a missfire. Come to think of it, I just started my car the other day open headers with no o2 sensors and didn't get any misfires. Prolly just a leak in the ignition system somewhere.
  7. #7 Re: Car throwing CEL
    Take a look down the back of the engine at #6 (closest to driver side). You want to make sure the wire isn't touching the O2 or the wiring to the O2. This is fairly common.
  8. #8 Re: Car throwing CEL
    Palmdale
    Quick update... found the #6 wire was burned in two spots. Plus my 02 sensor was very loose. The car has stop stuttering. I got a new spark plug wire. I do not think the 02 sensor are bad. So I more then likely return those sensor and get my 116 bucks back. Once my car cools down I will change everything and update you all. Just happy it is not looking like I need a ICM or a new coil.
  9. #9 Re: Car throwing CEL
    St. Louis
    Heck, I'd rather change the ICM or a coil before having to screw w/ #6 cylinder and the O2 back there, lol... Used ICM and coil from a JY is cheap(er). Good that you got it figured out.
  10. #10 Re: Car throwing CEL
    Another happy customer!
    Fordy.. c'mon.. #6 is cake and the O2 doesn't have to fight. (I really miss that Bonne exhaust manifold when working on a GP though)
  11. #11 Re: Car throwing CEL
    Palmdale
    well we hope this is what fixes it...... Just by looking at it a wire that is burned and a loose 02 sensor would explain the issue. Once my car gets cool enough I will change them and see if that fixes it.. But thanks everyone for you input.
  12. #12 Re: Car throwing CEL
    I thought you already made the changes. Who waits for a car to cool? C'mon ... get it done!
  13. #13 Re: Car throwing CEL
    Palmdale
    I had to get my kids from school too. So
  14. #14 Re: Car throwing CEL
    Nov 2011
    NY
    Lolz (waiting for cool engine)
  15. #15 Re: Car throwing CEL
    Palmdale
    Hell yea my motor bay gets hot as hell.I have already been burned once before!!!The cable auto zone gave me was to big... They gave me 8mm instead of a 7mm. so I have to take another trip to the auto part store
  16. #16 Re: Car throwing CEL
    St. Louis
    At least nobody mentioned unhooking the front mounts and rocking the engine forward for more space back there. I agree on the Bonne. My 95 is easier than my 00 GP for sure.
    dmack- Pop the hood and drink a beer, then change the wires and O2. 12oz. is usually enough cooling time to get started. Then start car and drink another beer while you listen to it purr
  1. Just throwing this out there
    By DirtDog in forum Off Topic Discussion
    Last Post: 12-21-2012, 06:43 PM
  2. Throwing all my GTP parts into the trash
    By BobC in forum 1991-1994 5 speed Manual (GETRAG 284,282)
    Last Post: 08-13-2011, 06:42 AM
  3. Throwing codes
    By batman1988 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2011, 03:37 PM
  4. throwing a code ive never seen before, helppp!!
    By kirkkarem1212 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2010, 08:06 PM
