Thread: Cut off tool or sawzall???
Results 1 to 8 of 8
  1. #1 Cut off tool or sawzall???
    Sep 2012
    Dealership
    I work on mostly family cars, so I don't need something too expensive. I'm looking to buy something that I can cut off tie rods, stabilizer pins, bolts etc when they will not come out. Whats the best thing to get? What brands? I know Harbor Freight sales this type of stuff.... I'll probably be using it only a few times a year.
  2. #2 Re: Cut off tool or sawzall???
    I would prefer a cut off tool if you are worknig under and in tight spots because its way smaller.
    A sawzall is great if you are cutting stuff with alot of room.
  3. #3 Re: Cut off tool or sawzall???
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    just get like a 4.5" angle grinder with a cut off wheel...and for the tight spots use a die grinder with the real small cut off wheels.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  4. #4 Re: Cut off tool or sawzall???
    You are going to fight a long time if you are cutting a tie rod. They are hardened and won't cut easily with a cut off wheel or sawzall.
    HF's earthquake brand is pretty nice. I have the air ratchet and love it. Ton's of power. I have one of their cheap cutoff wheels as well. Thing there is it'll use a ton of air and stop pretty easily.
  5. #5 Re: Cut off tool or sawzall???
    Sep 2012
    Dealership
    OK thanks guys.
  6. #6 Re: Cut off tool or sawzall???
    My sawzall cuts them easy
  7. #7 Re: Cut off tool or sawzall???
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    ive had to cut endlinks on one car i had, ruined my sawzall blade in the snap of a finger
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  8. #8 Re: Cut off tool or sawzall???
    GT Level Member Shiftingshaddow's Avatar
    KC
    cut the stud, not the joint. sawzall works fine.
    saw my bro use a skill saw with a metal blade. complete redneck way to do it. i laughed. he was cutting the joint. i asked him why not cut the stud and he was like, "i hadn't thought of that"
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  1. I need a tool.
    By MADGTP in forum Northeast
    Last Post: 10-08-2012, 04:15 PM
  2. I think i screwed myself, got carried away with sawzall, any bright ideas??
    By Black97GTP2dr in forum General Tech Discussion
    Last Post: 09-04-2012, 05:47 AM
  3. New tool box setup
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 02-09-2010, 07:32 PM
  4. Tool Time
    Last Post: 12-28-2009, 10:13 PM
  5. need tool
    By badbrad in forum General Tech Discussion
    Last Post: 05-10-2009, 01:03 AM
