Thread: 2001 Grand Prix Radiator
Results 1 to 8 of 8
  1. #1 2001 Grand Prix Radiator
    Hollister Mo
    Has anyone replaced original 5/8 core radiator with 1inch thick GTP radiator? If so, any problems or are they direct fit?
  2. #2 Re: 2001 Grand Prix Radiator
    GT Level Member Utter99's Avatar
    Warsaw indiana
    I replaced mine with one from a 98 Monty . It's 1 1/8 thick if I remember . I had to get the Monty lower radiated hose but everything just bolts right in and sensors are swapped fin.
    The only down side is that the drain is in a different location and it is a little messier to drain the coolant out
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  3. #3 Re: 2001 Grand Prix Radiator
    St. Louis
    I installed the HD 98 Monte Rad in my 00 GPGT as well. 1 3/8" thick core. Here's the write-up I did on it incl. pics.
    http://www.grandprixforums.net/radia...gps-67283.html
  4. #4 Re: 2001 Grand Prix Radiator
    Hollister Mo
    OK guys, thnx on that info about swapping to Monty cores. However, I'm just looking to put thicker GP radiator in.
  5. #5 Re: 2001 Grand Prix Radiator
    St. Louis
    You do know the Monte is the same platform as the GP's, right? All W-bodies. But go with what you need to. I just always figure if it's broken then might as well upgrade when I can if the price is good.
  6. #6 Re: 2001 Grand Prix Radiator
    Hollister Mo
    Thanks FordMan, yes knew about W-bodies. Just trying to keep it simple, if I can swap thicker radiator for thin one with no mods, it makes it a no brainer.
  7. #7 Re: 2001 Grand Prix Radiator
    gt and gtp swap no problem.
  8. #8 Re: 2001 Grand Prix Radiator
    St. Louis
    Quote Originally Posted by ddecker70 View Post
    I hear ya. Since not everyone knows cars are a W-body I figured I'd throw it out there.
  1. 92 Grand Prix radiator fans
    By 92GrandPrixLE in forum General Tech Discussion
    Last Post: 06-05-2010, 05:38 PM
