Thread: valve cover gasket
Results 1 to 19 of 19
  1. #1 valve cover gasket
    new york
    I was wondering if anyone knows if theres a site to that shows how to replace valve cover gasket??
  2. #2 Re: valve cover gasket
    Depending on which motor you have, this would change slightly.
    The basics are move the few things in the way, clean surfaces, put new gasket and grommets in, then torque to 89inch lbs and put stoff back in the way.
  3. #3 Re: valve cover gasket
    new york
    i have a 2001 grand prix gtp supercharged i was looking for a how to but cannot find anything about valve covers
  4. #4 Re: valve cover gasket
    1. Disconnect negative battery terminal
    1a. Remove passenger side dog bone 15mm from rad support to engine bracket.
    2. Unhook 7mm icm connector.
    2a. Disconnect all plug wires at coil packs
    3. Remove both belts
    4. Remove 13/15mm nut holding ground to ICM stud (above and right of the water pump)
    5. Remove ribbed idler pulley (15mm)
    6. Remove SC tensioner (13mm nut in middle of tensioner pivot), and set assembly aside.
    7. Loosen 15mm nut on front ICM stud
    8. Remove 13mm/15mm nut holding ground wire to stud. Then 15mm to remove stud
    9. Using E torx bit, loosen and remove the two studs from the head while supporting coil pack bracket.
    10. Valve cover is now fully accessable. Change gasket/grommets and clean surfaces.
    11. Reassemble.
    Rear:
    1. Remove alternator 13mm/15mm and SC to alt support bracket with Evap etc.
    2. Loosen all bolts 13mm/15mmon the alternator bracket. (Key is you are going to wiggle this instead of draining coolant)
    3. Remove map bracket and EGR shield 10mm
    4. Wiggle alt bracket to clear the valve cover and do the gasket.
  5. #5 Re: valve cover gasket
    GT Level Member Shiftingshaddow's Avatar
    KC
    if i remember right you will need the two plastic elbows in the belt tensioner replaced because they will break for sure when taking the tensioner off. its the big bracket that has two small coolant hoses going into right by the alternator. you have to take that off to get to the bolts on that side of the valve cover and to be able to pull the cover off. they will have to be scraped clean and you will need a pick tool to get all the plastic out. clean up the metal where the elbows go in really well and probably use some kind of gasket sealant or something when putting those elbows back in. they are like 2 bucks at oreillys. pain. i dread those things every time i have to deal with them. if you have coolant leak after you are done, it is those two elbows. you can see one on the top. its a 90 plastic elbow, maybe 1/2 in diameter. the other is underneath and you can feel it. you can see it a little if you take the coolant box off.
    p.s. don't try finding it while the car is running.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  6. #6 Re: valve cover gasket
    Elbows are super easy, no sealant needed. But if you wiggle a bit, you won't replace them or the coolant.
  7. #7 Re: valve cover gasket
    KC
    you are lucky man i guess. they sure break every time i deal with them. and leak. i didn't use any sealant so i am going to from now on.
  8. #8 Re: valve cover gasket
    new york
    anyone got any pics?
  9. #9 Re: valve cover gasket
    Pics of what? I have a billion pics of trillions of things.
    Photobucket.com
    psd: Boosted (case sensitive)
    Shifting: I do way too many to be lucky.
  10. #10 Re: valve cover gasket
    Apr 2012
    nova
    bill,
    when buying valve cover gaskets, do they typically come with the gromits?
    1999 gtp coupe... P&P heads, lim, and sc, comp vs cam, intake, dp and ubend
    2003 ford ranger fx4 level II- twin stick
  11. #11 Re: valve cover gasket
    If they're the Felpro ones they typically do
    04 Comp G.
  12. #12 Re: valve cover gasket
    Depends on if you get the part number with them or without them.
    VS50465R.........Valve Covers (L67) w/grommets................$40.79
    VS50080R.........Valve Covers (L36) w/o grommets...............$9.38
    ES72833...........Valve Cover grommets..............................$7.26
    I've seen a part number for L67 without, but ...why bother listing.
    http://www.grandprixforums.net/commo...ets-39796.html
  13. #13 Re: valve cover gasket
    new york
    pics of valve cover gasket replacement
  14. #14 Re: valve cover gasket
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    First thing I'd do is call your dealer and see if its already been serviced for this, GM put out a recall on the VC gaskets and the dealer has to replace them for free if it already hasn't been done
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  15. #15 Re: valve cover gasket
    Ocala, FL
    Quote Originally Posted by asite57 View Post
    Not gasket"s", the recall is for the front VC gasket only, on the supercharged engines.
  16. #16 Re: valve cover gasket
    Ocala, FL
    http://www.cpaclubgp.com/misc/lim-gasket.html
    Also check out this video.
    They're doing far more than valve cover gaskets, but this should really help you.
  17. #17 Re: valve cover gasket
    The essentials of what they do is maybe a front VC with or without grommets. Remove the heat shield from the exhaust, remove the wire holder (above the damn gasket..lol) and put clips on the wire.
    Personally, I'd replace the gasket myself. Remove the heat shield and be done.
    Kawa.. you want pictures of it.. go search my photobucket,
  18. #18 Re: valve cover gasket
    Oct 2011
    Michigan
    I just assumed we were talking about an L67
  19. #19 Re: valve cover gasket
    SE Level Member teejay's Avatar
    Feb 2013
    ohio
    Quote Originally Posted by kawasakidrivinghick View Post
    I would remove the plastic elbows and throw them in the trash and get a set of the Dorman aluminum ones and you won't have to worry about them ever again.
  1. Valve Cover Gasket?
    By Below Average Joe in forum General Grand Prix Discussion
    Last Post: 09-10-2012, 08:20 AM
  2. rear valve cover gasket ?'s
    By twol8uluz in forum General Tech Discussion
    Last Post: 04-30-2011, 09:49 PM
  3. Valve cover gasket
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2011, 05:11 PM
  4. Valve cover gasket
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2009, 10:25 PM
  5. valve cover gasket
    By BFish in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-12-2008, 03:51 PM
