Thread: 3400 sfi H.O.
Results 1 to 7 of 7
  1. #1 3400 sfi H.O.
    Feb 2013
    council bluffs iowa
    need some help with a 99 pontiac grand am gt H.O. 3400 sfi. Its starting rough due to low fuel presure. it has a new fuel pump and the fuel lines have all been ran through. and for some reason all of the lights on the dash are on. Feel free to leave any advise thanks
  2. #2 Re: 3400 sfi H.O.
    Junk pump replacement?
    You said the lines have been ran through, assuming you have a new fuel filter as well?
    Maybe there is a clog in the rail or...start checking fuses/relays/wiring to make sure its getting a solid connection.
    Also, this section is for the 3.4 DOHC...I'll move it for you
  3. #3 Re: 3400 sfi H.O.
    I live here. TLSheff's Avatar
    Did you replace the fuel pump?
    Is it running rough all the time, or just idling?
    Does it cut out when driving?
    What all codes are showing up?
    (Go to a close auto place, they have scanners you can use for free to check codes, write each down Pxxxx - description, come back and well go from there)
  4. #4 Re: 3400 sfi H.O.
    Bad Fuel pressure regulator can cause low FP at start up too.
  5. #5 Re: 3400 sfi H.O.
    Mar 2012
    Minnesota
    Yeah check fuel pressure reg.
  6. #6 Re: 3400 sfi H.O.
    Feb 2013
    council bluffs iowa
    its just when your starting it and yes filter and pump are new and thanks ill look into it now
  7. #7 Re: 3400 sfi H.O.
    I had a problem getting a 3100 running at start up and it was a lazy fuel pump. It's possible you got a bad one.
  1. 3400 thermostat
    By loopy smurf in forum 3.4L V6 (LQ1) DOHC
    Last Post: 01-04-2013, 10:11 AM
  2. HELP 3400 swap into 3100
    By ssgtarivera in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-17-2012, 12:53 PM
  3. For You 3100/3400 Guys!
    By blueguy in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-26-2011, 05:21 PM
  4. 3400 uim on a 3100
    By mhartwig in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-08-2010, 01:13 PM
