Is there any reason why I cant bolt this beautiful gen 5 eaton m90 onto my gen 3 ssm90 lower intake manifold? The lower intake has the inlet moved forward already, I have the skinny 60lb siemens injectors so clearance shouldent be an issue. I will just need to do a little grinding for clearance for the fuel rails and the one injector as far as I can tell and then the normal genv swap stuff.
