What's up everybody. I have a 97 gtp coupe. The issue is my driver's window rolls down perfectly fine but when I go to roll it up it goes pretty slow then when it gets almost to the top the front seems to hang up or something which makes the top corner stick out. After it gets about half way I usually have to help it up so it doesn't burn my switch out or something.
http://www.grandprixforums.net/windo...nny-47058.html
It's basically the same issue this guy was having, I'm just curious if anyone figured out how to fix it.
I took it all apart the other day and cleaned the tracks up and spray everything down with some graphite lubricant, but it didn't seem to help at all. Nothing appeared to be broken, and none of the regulator cables were tangled up or anything so I'm kinda puzzled at this point.
Any help would be great, thanks!
