Thread: Suspension noise.... Is something going bad?
Results 1 to 9 of 9
  1. #1 Suspension noise.... Is something going bad?
    Oct 2012
    Detroit Area
    I have an 04' GT1 GP with around 106K on the ODO. I've noticed recently (more so in the cold) that my front drivers side suspension makes noise when I go over speedbumps in my neighborhood.. I hate those speedbumps..... But anyways, the noise seems to be more prevalent when the car is cold and hasn't been driven recently. So... that being said, I can't replicate this when I put the car on jack stands. Nothing seems loose. Is there anything that commonly goes bad in the front suspension? A bushing perhaps? Also, what ALL is greasable in the front end suspension?
    Thanks!
    -Ken
  2. #2 Re: Suspension noise.... Is something going bad?
    First bet would be sway link, pretty common for them to make noise.
    They are cheap and a easy repair most of the time.
  3. #3 Re: Suspension noise.... Is something going bad?
    Oct 2012
    Detroit Area
    Sway bar end link you think? That's not a bad repair and it's something I can do myself, I might look in to some prices on that The suspension ACTS just fine, I'm just worried that the noise will eventually lead to another problem -__-
  4. #4 Re: Suspension noise.... Is something going bad?
    When you say it just happens over bumps, thats what first comes to mind. I see it all the time where its either a sway link or the struts themselves.
    04-05 gps have the really long sway bar link unlike the 97-03 and 06-08 cars.
  5. #5 Re: Suspension noise.... Is something going bad?
    Ocala, FL
    You said it makes a noise, but there's lots of noises out there! Is it a pop, creak, squeak, bang? Only over bumps, never low speed turns or anything else?
    Have you looked under the car to make sure nothing is broken? Sometimes the sway bar will actually crack.
  6. #6 Re: Suspension noise.... Is something going bad?
    Oct 2012
    Detroit Area
    I Just replaced the wheel hub/bearing assemblies and the front discs/pads. Nothing noticeably broken..
  7. #7 Re: Suspension noise.... Is something going bad?
    Oct 2012
    Detroit Area
    I will definitely check out the sway bar link ends tomorrow though!
  8. #8 Re: Suspension noise.... Is something going bad?
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    LCAs?
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  9. #9 Re: Suspension noise.... Is something going bad?
    Jan 2013
    michigan
    ^^^^^ this. check the lower control arm bushings to. mine are bad and my car makes noise anytime i hit a bump
  1. Rear Suspension Noise Driving me Crazy HELP
    By 94GrandPrixSE in forum Brakes/Suspension/Chassis
    Last Post: 01-22-2013, 10:44 PM
  2. Gee Bob, maybe we should have had that suspension noise looked at?
    By buickman104 in forum Off Topic Discussion
    Last Post: 11-16-2012, 02:36 PM
  3. New GXP Owner-Questions about suspension noise?
    By sbronemann in forum Brakes/Suspension/Chassis
    Last Post: 05-11-2012, 11:32 PM
  4. loud noise from front suspension
    By runn141 in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2010, 08:39 PM
  5. Suspension Making Noise in Cold Weather
    By anishtulsian in forum Brakes/Suspension/Chassis
    Last Post: 12-10-2009, 02:17 PM
