Thread: DIC MPG flucturating
Results 1 to 14 of 14
  1. #1 DIC MPG flucturating
    Donating Users smitz327's Avatar
    Oct 2012
    Illinois
    I have a 2000 GT and the MPG fluctuates badly, Just filled it up the other day and maybe driven it maybe 20 miles city and already an 1/8 of a tank is gone. Getting like 8 to 10 miles to gallon from what it says; it has never been very accurate. On the highway when I open it up to say 70 MPH, the MPG stabilizes to around 25 MPG and maybe 340 to the highway on a tank. I have a cold air intake in it also. I also smell oil and gas while sitting at a light or when I back the car in to garage. The car runs very good and smooth it seems, no hiccups or sputtering.
  2. #2 Re: DIC MPG flucturating
    If it smells like oil and gas it is probably leaking somewhere. Check the fuel lines and LIM gasket.
  3. #3 Re: DIC MPG flucturating
    HUDSON
    Definately a leak, check the fuel rail connection o-rings.
  4. #4 Re: DIC MPG flucturating
    Nov 2012
    Madison
    25 on the highway is at least a good sign. Being that you are in Illinois and it is winter would cause city driving averages to go to hell. Idling,warming car up, sitting at lights longer, tires spinning in the snow,etc makes my car go into the 10mpg range in a heartbeat. The MPGs sound normal this time of year, especially in snow states.
    As far as that smell, I would hope you have done some visual inspections.
  5. #5 Re: DIC MPG flucturating
    Oct 2012
    Illinois
    This weekend the weather has been nice in the 50's clean roads, just normal driving
  6. #6 Re: DIC MPG flucturating
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    What is flucturating? Lol
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
  7. #7 Re: DIC MPG flucturating
    SWPA
    The DIC is not very accurate. Also sitting in city traffic with stop lights will kill gas mileage. The gauge isn't super accurate either. I can be driving and it won't move off of full, then all of a sudden it is down to 3/4 tank.
    Use mileage driven divided by fuel used to figure out actual mpg.
  8. #8 Re: DIC MPG flucturating
    Pennsylvania
    If you're not checking your mileage vs fuel-up, you can't be sure if there's a problem at all. '97-'03 PCM does bad math on fuel.
  9. #9 Re: DIC MPG flucturating
    I'm thinking the issue is a little deeper than the DIC.
    Might be time to stop by the mechanic.
  10. #10 Re: DIC MPG flucturating
    Oct 2012
    Illinois
    I think you are right, probably going to drop it off at GM. I am wandering maybe that cold air intake is causing all the problems. It gets good gas mileage highway but bad local driving. I am usually easy on the peddle
  11. #11 Re: DIC MPG flucturating
    Oct 2012
    Illinois
    One thing I did try is take the MAS out to check it and make sure it is clean, no problems found, looks clean
  12. #12 Re: DIC MPG flucturating
    It can look clean but you need to clean it with spray to make sure
  13. #13 Re: DIC MPG flucturating
    Oct 2012
    Illinois
    I took your advice and cleaned the MAS with contact cleaner that is safe for plastic and blew it dry. Not sure if it is to early to tell but I took it down to the store and noticed a huge difference on the DIC and after resetting it, it averaged around 20 MPG. I understand it is not accurate but before it was reading 12 or lower. I will keep the thread updated.
  14. #14 Re: DIC MPG flucturating
    Oct 2012
    Illinois
    Update! ran the tank of gas out and got just under 200 miles to the tank full and that is from the mileage on the gage cluster. Not very good for $45 dollars worth of gas
