Thread: Key Stuck in Ignition/ wont start
Results 1 to 4 of 4
  1. #1 Key Stuck in Ignition/ wont start
    Dec 2012
    Lowell
    So I was driving my car, its a 2000 GTP, about an hour before this happened and it was perfectly fine. I went to start it and the first turn of the key the car did its normal thing and all the dash lights came on but when I went to start it, NOTHING happened, all the lights went off and the key was stuck in the ignition. No lights work at all, cant shift, and it wont start, the only way to get the key out is the manual release under the steering column..can anyone help??
  2. #2 Re: Key Stuck in Ignition/ wont start
    dead battery, bad grounds, or loose or dirty battery connections or grounds?
  3. #3 Re: Key Stuck in Ignition/ wont start
    Arizona
    Checked yourrrr battery?
  4. #4 Re: Key Stuck in Ignition/ wont start
    Dec 2012
    Lowell
    Thanks guys, it was the negative terminal on the battery ,I tightened it down and everything worked
  1. Key stuck in ignition, shifter wont move with key on...
    By robstout in forum General Tech Discussion
    Last Post: 04-06-2013, 07:45 PM
  2. Key stuck in ignition, won't start, won't shift out of first park !!.
    By microterf in forum Audio, Security & Visual Electronics
    Last Post: 09-29-2012, 08:44 AM
  3. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  4. 97 GP GT ignition key wont turn back after start...
    By AREED in forum General Tech Discussion
    Last Post: 12-23-2010, 09:07 AM
  5. Key stuck in ignition & shifter wont release!!
    By Pontiac 2003 in forum General Tech Discussion
    Last Post: 04-03-2010, 12:54 PM
