Thread: 99 GT temp gauge runs high
Results 1 to 9 of 9
  1. #1 99 GT temp gauge runs high
    Oct 2012
    Las Vegas
    Having some issues with a 99 GT. The gauge runs about 3/4 of the way up but actual temp at the therm housing reads normal. Also, the fans dont seem to be coming on. Ive hard wired the fans and they work, replaced the relays, fuses are fine. installed a new temp sensor. Anybody have any ideas of what could be going on?
    EDIT...Im starting to suspect the ECM. Does anybody know if I pull one from an identical parts car if it has to be programed or will it be plug and play???
  2. #2 Re: 99 GT temp gauge runs high
    Changed the coolant or thermostat yet? Or tried bleeding the cooling system of air?
  3. #3 Re: 99 GT temp gauge runs high
    Oct 2012
    Las Vegas
    yep, thermostat was changed about 2 wks ago and have bled the system
  4. #4 Re: 99 GT temp gauge runs high
    Oct 2012
    Las Vegas
    hmmm thats all? nobody has any insight to this???
  5. #5 Re: 99 GT temp gauge runs high
    dutchess county,n y
    maybe gauge is just not accurate and fans are not coming on because temp is getting hot enough to kick them on ?
  6. #6 Re: 99 GT temp gauge runs high
    im having the same problem with my 02, different motor but same problem, my gauge on the dash reads about 10* hotter then what the computer says tho but the engine doesnt get that hot.
    So im in the same sinking boat as you
    SMGPFC Member #10
  7. #7 Re: 99 GT temp gauge runs high
    Watch out.. GP's can fill with water quickly and sink into the ocean.
  8. #8 Re: 99 GT temp gauge runs high
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    ^^^^ Very true LOL!!! I've had water in my upper intake, lower intake, cyl's, and floor board..... I might have one of them boat cars, with holes in it....
    Seriously though... sounds like you've done what's needed... is your radiator clogged at all (when car is at running temp you can put your hand on the radiator and feel for different temperature spots)? Do you still have heat? Do you appear to be losing coolant?
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  9. #9 Re: 99 GT temp gauge runs high
    Donating Users smitz327's Avatar
    Oct 2012
    Illinois
    My fans never come on in 2000 GT, but my gauge reads about 160 to 180. Did the same things you have done so I am pretty sure you just got a bad gauge. One question I do have, what temp should the car run to get the best gas mileage? One thing I did to my GT is get a cold air intake and that made my gas mileage worse. I have a 2002 GTP that's gets much better gas mileage than the GT
  1. coolant leak! temp very high.
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-14-2011, 04:37 PM
  2. Engine runs fine till temp starts to rise...
    By 97gpGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2010, 11:22 AM
  3. 99 GTP runs fine cold, seems to lose a cylinder when up to temp?
    By 99GTPJay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 07:26 AM
