Thread: Friends gtp won't start. Stumped.
Results 1 to 10 of 10
  1. #1 Friends gtp won't start. Stumped.
    Dec 2010
    DMV
    Ok a few days ago a good friend of mines car wouldn't start. So we've went down the list and this is what we have ruled out.
    It's a 1997 gtp
    Ok, CPS replaced, ICM replaced and he put his stock PCM as well instead of the tuned one from zzp
    Ok so where should we start?
    Also we checked the fuel pump (because we snatched it from the junk yard when the old one went out) pressure by pressing the fuel a schader valve and I saw that the gas just dripped out inside of shooting out like mines does. Car will crank but it won't start.
    Any help?
  2. #2 Re: Friends gtp won't start. Stumped.
    You determine if you are missing spark or fuel. Sounds like you shotgunned the spark components, then realized..you have no fuel.
  3. #3 Re: Friends gtp won't start. Stumped.
    Pennsylvania
    Impossible to know fuel pressure without a gauge.
  4. #4 Re: Friends gtp won't start. Stumped.
    Dec 2010
    DMV
    Ok cool. I'll start Witt the pressure
  5. #5 Re: Friends gtp won't start. Stumped.
    Dec 2010
    DMV
    New fuel installed. Still no start. We installed a new cuz it needed a new one lol. Any ideas where to start at?
  6. #6 Re: Friends gtp won't start. Stumped.
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    fuel pressure/spark.................. which are you missing..........
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  7. #7 Re: Friends gtp won't start. Stumped.
    Pennsylvania
    Shotgunning spark and fuel... make sure the injector fuse is good.
    Maybe we're missing air. Throttlebody stuck closed?
  8. #8 Re: Friends gtp won't start. Stumped.
    Jan 2013
    Edmonton, Alberta
    yes i am, even so knowing those 2 things will help point you in the right direction, they tell a good story
    edit: i would start by checking spark on any cylinder with a load tester, if its there then i would put a fuel pressure gauge on the rail, if its there i would check any injecter with a node light, if its there then i would consider air,
    thats the typical (turn over,no start) check for me , should take no time to do this, and it might not find your problem but it tells you alot.
  9. #9 Re: Friends gtp won't start. Stumped.
    Never Never Land
    How bout the good ol' fuel pump relay that has issues on the 97-99's or whatever it is.
  10. #10 Re: Friends gtp won't start. Stumped.
    Jan 2013
    Edmonton, Alberta
    if you checked fuel pressure you would consider that
  1. Stumped! need some help on this one!
    By Damon318 in forum General Tech Discussion
    Last Post: 11-04-2010, 11:30 AM
  2. Ok Im stumped...PLEASE HELP!!
    By sinceregtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2010, 06:27 PM
  3. Stumped
    By Vern in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2010, 10:45 AM
  4. my gt vs my friends comp g vs my friends 00' gtp
    By uNda6gT in forum Track Sessions and Kills
    Last Post: 04-26-2009, 11:18 AM
  5. stumped
    By lucidGTP307 in forum General Tech Discussion
    Last Post: 03-16-2009, 09:36 PM
