Thread: What did I wire wrong?
Results 1 to 8 of 8
  1. #1 What did I wire wrong?
    Feb 2010
    TN
    Ok finnally did the big one upgrade ran a 4 guage battery cable (modded one end to fit) from the front fuse box bolt (under the red battery jumper connection) to the bolt under the rubber boot on the alternator. Car used to start fine with the first tap of the key now it cranks a bit first takes about 10-15 seconds of cranking windows do not seem any faster interior lights are brighter though. I did go to the right spots correct?
    97 grand prix gt N/A 3800 if that helps.
    Thanks
    I live here. DirtDog's Avatar
    Jun 2012
    Usually when I see people do this they do the big 3. Batter directly to alternator. Ground wire to the transmission bolt and one more ground to the frame of the car. And I helped a friend with a high end sound system do his and it worked greatly.
    Sent from my DROID RAZR using Tapatalk 2
  3. #3 Re: What did I wire wrong?
    Feb 2010
    TN
    Ahh no one mentioned the gound wires for fran tranny and frame to where?
    Jun 2012
    A guy who did it in his 3.8 used the top bolt on the transmission on the side the starter is on. I think...don't quote me but its a diff cover or something like that. And the best place for the new ground to frame is one of the strut tower bolts and sand it super good first. Also make sure u use solder on the end connections and not just crimp them onto the wire. And one more thing from research I've done on this the best size wire to use is 2gauge and lower
  5. #5 Re: What did I wire wrong?
    1. Either the positive battery post or the relay center post (that you used) to the alternator.
    2. From the negative battery post to the engine (honestly any bolt to the engine or transmission will work)
    3. From the negative battery post to the body.
  6. #6 Re: What did I wire wrong?
    Feb 2010
    TN
    same guagewire for the grounds as well?
  7. #7 Re: What did I wire wrong?
    Why would you use anything less?
  8. #8 Re: What did I wire wrong?
    Feb 2010
    TN
    Kinda what I was thinking I thought I saw where texas tanker said he just did it without grounds but I must have read it wrong, was just wishing I could use the pitail off the ngstive battery cable since it was handy easy and fast getting cold out was trying to cut a corner here lol and I guess I need to do steps two and three not two or three huh bill.
  1. Looking for some speaker wire and a new ground wire.
    By Bluemagic in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 08:41 PM
  2. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  3. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  4. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  5. Something's Very Wrong
    By BwolfGT in forum Track Sessions and Kills
    Last Post: 04-24-2009, 10:04 PM
