Thread: Climate control issue...Please Help
Results 1 to 6 of 6
  1. #1 Climate control issue...Please Help
    Feb 2013
    Minnesota
    So my girlfriend is having a problem with her 2002 grand prix. At first the fan settings 1-2 went out and only worked on 3, 4, and 5. About a year later 3 and 4 went out and it only worked on 5. We have just been settling on having it work on 5 until today it stopped working all together. Now none of the fan speed settings work, no a/c, no heat (which is a pretty big problem in the minnesota winter climate right now) so I'm looking for some advice where do i start? The resistor? the fuses? any info will be greatly appreiciated as I want to get this fixed asap (at least so her heat/defrost can work for the meantime) Thanks!
  2. #2 Re: Climate control issue...Please Help
    Feb 2013
    Minnesota
    it is also not the digital version just the plain jane dual zone i think it's called...
  3. #3 Re: Climate control issue...Please Help
    Omaha, NE
    Blower motor resistor
    Let me google that for you
  4. #4 Re: Climate control issue...Please Help
    GT Level Member aligater's Avatar
    london ontario canada
    before doing anything, try giving the blower motor a tap with a hammer while it's set to #5. might be the blower gave up suddenly, but you definately need the resistor to fix #1-4.
  5. #5 Re: Climate control issue...Please Help
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    i have said resistor
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
    GT Level Member chrishova's Avatar
    Norfolk, Virginia, United States
    Thanks! I needed this too!
    Sent from my Galaxy
  1. Climate control issue
    By kingjohn1027 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2012, 09:25 AM
  2. dual climate control issue
    By bigdawg00 in forum General Tech Discussion
    Last Post: 11-09-2011, 06:37 AM
  3. Climate Control Issue, please help!
    By heathersmanforlife in forum General Tech Discussion
    Last Post: 06-04-2011, 01:10 PM
  4. Dual climate control issue
    By mr_gtp in forum General Tech Discussion
    Last Post: 12-22-2009, 07:14 AM
  5. Climate Control Issue - Help!
    By sb7605 in forum General Tech Discussion
    Last Post: 12-17-2009, 10:50 AM
